I am trying to ping 10.99.0.249 which has static route on eth3 but on tcpdump i can see its not even generating ping request. On the other hand when i try to ping eth3 which has 10.100.1.5 from 10.99.0.249 the echo requests are coming but no echo reply sent back. On the interface there is no firewall setting. I have even tried by putting firewall on eth3 which specifically allow 10.99.0.249 but currently there is no firewall setting. I need to have connectivity with 10.99.0.249 please help me acheiving that.
show ip route 10.99.0.249
Routing entry for 10.99.0.248/29
Known via “static”, distance 1, metric 0, best
10.100.1.4, via eth3.31
Below is the static route:
set protocols static interface-route 10.99.0.248/29 next-hop-interface ‘10.100.1.4’
set interfaces ethernet eth3 duplex ‘auto’
set interfaces ethernet eth3 hw-id ‘68:05:ca:25:dd:74’
set interfaces ethernet eth3 ip source-validation ‘disable’
set interfaces ethernet eth3 smp_affinity ‘auto’
set interfaces ethernet eth3 speed ‘auto’
set interfaces ethernet eth3 vif 31 address ‘10.100.1.5/31’
set interfaces ethernet eth3 vif 31 ip source-validation ‘disable’
Thanks in advance. If you need more information in understanding the issue please let me know,
