Policy Routing Not Working Wireguard
not sure if this was meant for me but yes commiting and saving also i treid removing the config saving rebooting adding it back in saving then rebooting and same issue
I finally had some time to sink into this issue and solved it.
The problem was the option that was enabled under pppoe0 default-route force:
force: A default route is added after removing all existing default routes."
To remedy this:
set the default route option to auto then
set protocols static interface-route 0.0.0.0/0 next-hop-interface pppoe0
now issues are all gone and happiness is restored :slight_smile:
