What is the correct way to remove a prefix list associated with a route-map or a BGP neighbor? I deleted the prefix list in question but it seems it is still associated with the route-map and neighbor in question. What is the correct procedure to follow to correctly and completely remove a prefix lis?
Thanks!
Can you post your config, and the command you used to remove the prefix list?
Config before:
policy {
prefix-list FILTER-IN {
rule 10 {
action permit
le 32
prefix 172.16.0.0/12
route-map AS-PREPEND-OUT {
rule 10 {
action permit
set {
as-path-prepend 65000
protocols {
bgp 65000 {
neighbor 169.254.0.1 {
as-override
prefix-list {
import FILTER-IN
remote-as 7224
route-map {
export AS-PREPEND-OUT
soft-reconfiguration {
inbound
timers {
holdtime 30
keepalive 10
neighbor 169.254.0.5 {
as-override
remote-as 7224
inbound
timers {
holdtime 30
keepalive 10
network 172.16.2.0/26 {
Below the command to remove the prefix list:
delete policy prefix-list FILTER-IN
Config after:
policy {
rule 10 {
action permit
set {
protocols {
bgp 65000 {
as-override
prefix-list {
import FILTER-IN
remote-as 7224
route-map {
inbound
timers {
holdtime 30
keepalive 10
as-override
remote-as 7224
inbound
timers {
holdtime 30
keepalive 10
Notice the prefix-list is still referenced within the BGP config.
I managed to clean this up by using the below:
delete protocols bgp 65000 neighbor 169.254.0.1 prefix-list import FILTER-IN
I was just under the impression that once a prefix-list was deleted, it would be removed everywhere in the config. Not a train-smash though.
