Problem is OpenVPN
I created a virtual environment.(see image)
http://3e2d02bee063.sn.mynetname.net/owncloud/index.php/s/p4np4U33MjItaEu
As OpenVPN connection is included with the laptop I can not get out into the world.
How do I delete a route on a laptop
sudo ip route del default via 10.10.10.1 dev tun0
it all works well.
My config:
VyOS -1 (server opnvpn)
vyos@vyos1# run show configuration interfaces { ethernet eth0 { address dhcp duplex auto hw-id 08:00:27:96:a6:27 smp_affinity auto speed auto } ethernet eth1 { address 192.168.255.2/30 duplex auto hw-id 08:00:27:b9:11:00 smp_affinity auto speed auto } ethernet eth2 { address 192.168.10.1/24 duplex auto hw-id 08:00:27:5a:10:b7 smp_affinity auto speed auto } loopback lo { } openvpn vtun0 { mode server openvpn-option "--mssfix --tun-mtu 1440" openvpn-option "--push redirect-gateway autolocal" protocol udp server { subnet 10.10.10.0/24 } tls { ca-cert-file /config/auth/ca.crt cert-file /config/auth/satkas-server.crt dh-file /config/auth/dh1024.pem key-file /config/auth/satkas-server.key } } } load-balancing { wan { flush-connections interface-health eth0 { failure-count 3 nexthop 192.168.99.1 success-count 1 test 10 { resp-time 5 target 8.8.8.8 ttl-limit 1 type ping } } interface-health eth1 { failure-count 3 nexthop 192.168.255.1 success-count 1 test 10 { resp-time 5 target 8.8.8.8 ttl-limit 1 type ping } } rule 10 { failover inbound-interface eth2 interface eth0 { weight 6 } interface eth1 { weight 4 } protocol all } } } nat { source { rule 100 { outbound-interface eth0 source { address 192.168.10.0/24 } translation { address masquerade } } rule 101 { outbound-interface eth1 source { address 192.168.10.0/24 } translation { address masquerade } } rule 102 { outbound-interface eth0 source { address 10.10.10.0/24 } translation { address masquerade } } rule 103 { outbound-interface eth1 source { address 10.10.10.0/24 } translation { address masquerade } } } } protocols { static { route 0.0.0.0/0 { next-hop 192.168.99.1 { } next-hop 192.168.255.1 { } } } } service { ssh { port 22 } } system { config-management { commit-revisions 20 } console { device ttyS0 { speed 9600 } } host-name vyos1 login { user vyos { authentication { encrypted-password **************** plaintext-password **************** } level admin } } name-server 8.8.8.8 ntp { server 0.pool.ntp.org { } server 1.pool.ntp.org { } server 2.pool.ntp.org { } } package { auto-sync 1 repository community { components main distribution helium password **************** url http://packages.vyos.net/vyos username "" } } syslog { global { facility all { level notice } facility protocols { level debug } } } time-zone UTC } vpn { ipsec { ipsec-interfaces { interface eth0 } nat-networks { allowed-network 0.0.0.0/0 { } } nat-traversal enable } l2tp { remote-access { authentication { local-users { username tkasprzycki { password **************** } } mode local } client-ip-pool { start 192.168.255.1 stop 192.168.255.255 } ipsec-settings { authentication { mode pre-shared-secret pre-shared-secret **************** } ike-lifetime 3600 } outside-address 192.168.99.16 } } }
route on a laptop before and after the VPN connection
before
default via 192.168.99.1 dev wlan0 proto static metric 400 169.254.0.0/16 dev wlan0 scope link metric 1000 192.168.99.0/27 dev wlan0 proto kernel scope link metric 400 192.168.200.0/24 dev vboxnet0 proto kernel scope link metric 100
after
default via 10.10.10.1 dev tun0 proto static metric 50 default via 192.168.99.1 dev wlan0 proto static metric 400 10.10.10.0/24 dev tun0 proto kernel scope link metric 50 10.10.10.0/24 dev tun0 proto kernel scope link metric 950 169.254.0.0/16 dev wlan0 scope link metric 1000 192.168.99.0/27 dev wlan0 proto kernel scope link metric 400 192.168.200.0/24 dev vboxnet0 proto kernel scope link metric 100
try taking this out openvpn-option “–push redirect-gateway autolocal”
Hi
This option is already set
I do not know what’s going on but today we worked well (OpenVPN)
But I have a problem with load balancing.
I turn on the router network is available and move out on eth0 (192.168.99.1)
I set
set ethernet interface eth0 disable
and
commit
Network to switch to eth1 and is ok[/code]
I set
del interface ethernet eth0 disable
and
commit
and now it does not switch automatically
vyos@vyos1# show load-balancing wan { flush-connections interface-health eth0 { failure-count 3 nexthop dhcp success-count 1 test 10 { resp-time 5 target 8.8.8.8 ttl-limit 1 type ping } } interface-health eth1 { failure-count 3 nexthop 192.168.255.1 success-count 1 test 10 { resp-time 5 target 8.8.4.4 ttl-limit 1 type ping } } rule 10 { failover inbound-interface eth2 interface eth0 { weight 255 } interface eth1 { weight 1 } protocol all } }
[code]vyos@vyos1:~$ show wan-load-balance
Interface: eth0
Status: failed
Last Status Change: Tue Oct 20 20:28:17 2015
-Test: ping Target: 8.8.8.8
Last Interface Success: 10m36s
Last Interface Failure: 0s
# Interface Failure(s): 58
Interface: eth1
Status: failed
Last Status Change: Tue Oct 20 20:29:35 2015
-Test: ping Target: 8.8.4.4
Last Interface Success: 9m18s
# Interface Failure(s): 51[/code]
vyos@vyos1# show protocols static { route 0.0.0.0/0 { next-hop 192.168.99.1 { } next-hop 192.168.255.1 { } } }
