Dear sir,
i am using vyos as pppoe-server.it has some issues . I couldn’t fine any option as keepalive timeout. because vyos takes 3 mins time to disconnecting user even it has power frailer
Arun Tamrakar
Pokhara Nepal
Dear sir,
Arun Tamrakar
Pokhara Nepal
Perhaps this command will help you?
set interfaces pppoe <interface> idle-timeout <time>
thanks for reply . this is not my solution , i am working on pppoe-server so, all the client that connected with the pppoe-server they are not disconnecting for 3 mins even clients has power frailer and cable disconnect . As you sent configuration is not found in pppoe-serve it found only pppoe-clinet ( dialup ). i wants know is there any option as keepalive timeout in vyos ?
Best Regards,
Do you use radius for pppoe sessions?
yes i use it radius for pppoe session
@linuxpkr hi, check the following hierarchy and options:
set service pppoe-server ppp-options
Possible completions:
ccp CCP negotiation (default disabled)
interface-cache
PPP interface cache
ipv4 IPv4 (IPCP) negotiation algorithm
ipv6 IPv6 (IPCP6) negotiation algorithm
ipv6-accept-peer-intf-id
Accept peer interface identifier
ipv6-intf-id Fixed or random interface identifier for IPv6
ipv6-peer-intf-id
Peer interface identifier for IPv6
lcp-echo-failure
Maximum number of Echo-Requests may be sent without valid reply
lcp-echo-interval
LCP echo-requests/sec
lcp-echo-timeout
Timeout in seconds to wait for any peer activity. If this option specified it turns on adaptive lcp echo functionality and "lcp-echo-failure" is not used.
min-mtu Minimum acceptable MTU (68-65535)
mppe Specifies mppe negotiation preferences
mru Preferred MRU (68-65535)
I think you need to tune lcp-echo-timeout
thanks it works … it has another issues …i am using DMA radius manager and i choose NAS = others . but it not accepting the radius server rules. not expires any clients and doesn’t disconnect that clients manually disconnected from radius manager task
Arun tamrakar
