Hi, I have router (VyOS) with below configuration:
eth0 - WAN
eth1 - LAN_1
eth2 - LAN_2
eth3 - LAN_3
I wouild like to limit download speed from Internet only for eth1 interface, but speed between LAN should still be high.
How I can achive this using QoS limiter traffic-policy?
Can you give me a working example for this case?
That won’t work. He wants to limit the bandwidth from the internet eth0 to eth1, so needs a limiter applied to the inbound side of eth0 for traffic destined to go to eth1. Assuming that eth1 uses 192.168.xx.yy
set traffic-policy limiter MYLIMIT class 10 bandwidth 300kbit
set traffic-policy limiter MYLIMIT class 10 description "Limit download speed"
set traffic-policy limiter MYLIMIT class 10 match ETH1 ip destination address 192.168.xx.yy
set interfaces ethernet eth0 traffic‐policy in MYLIMIT
