Before I spend the money on Hardware, can embody let me know if the Alix Board apu3b4 from PC Engine compatible with VyOS?
Spec:
[list]
[]CPU: AMD Embedded G series GX-412TC, 1 GHz quad Jaguar core with 64 bit and AES-NI support, 32K data + 32K instruction cache per core, shared 2MB L2 cache.
[]DRAM: 2 or 4 GB DDR3-1333 DRAM
[]Storage: Boot from SD card (internal sdhci controller), external USB or m-SATA SSD. 1 SATA + power connector. mSATA is shared with miniPCI express.
[]12V DC, about 6 to 12W depending on CPU load. Jack = 2.5 mm, center positive
[]Connectivity: 3 Gigabit Ethernet channels (Intel i211AT)
[]I/O: DB9 serial port, 2 USB 3.0 external + 4 USB 2.0 internal, three front panel LEDs, pushbutton
[]Expansion: 3 miniPCI express (J14 USB or mSATA, with SIM; J15 USB only, with SIM; J16: full miniPCI express, but no SIM, intended for wifi). GPIO header, optional I2C bus, COM2 (3.3V RXD / TXD).
[]Board size: 6 x 6" (152.4 x 152.4 mm) - same as apu1d, alix2d13 and wrap1e.
[]Firmware: coreboot (please contact [email protected] for source code if desired).
[]Cooling: Conductive cooling from the CPU to the enclosure using a 3 mm alu heat spreader (included).
[/list]
I attached front and back pictures of the ALIX apu3b4 system board.
Thank You;
MSquires
