I get an error when trying to enable IPV6 router advertisements on Vyos 32bit 1.1.7 and 1.2.0 beta 1. If I move the same configuration to a Vyos virtual 64bit on Hyper-V it works fine. Not sure if there are any newer build for 32bit or if support for this architecture has been dropped.
This is the exact error that I get
Starting radvd…
Starting radvd: [Apr 07 19:10:45] radvd: Could not daemonize.
This is the config I am trying to get working on the 32bit machine that works on 64bit. This config works on 64bit 1.1.7 1.2.0 beta 1
set interfaces ethernet eth1 ipv6 router-advert cur-hop-limit ‘64’
set interfaces ethernet eth1 ipv6 router-advert default-preference ‘high’
set interfaces ethernet eth1 ipv6 router-advert link-mtu ‘1280’
set interfaces ethernet eth1 ipv6 router-advert managed-flag ‘false’
set interfaces ethernet eth1 ipv6 router-advert max-interval ‘600’
set interfaces ethernet eth1 ipv6 router-advert other-config-flag ‘true’
set interfaces ethernet eth1 ipv6 router-advert prefix 2001:470:x:xx::/64 autonomous-flag ‘true’
set interfaces ethernet eth1 ipv6 router-advert prefix 2001:470:x:xx::/64 on-link-flag ‘true’
set interfaces ethernet eth1 ipv6 router-advert prefix 2001:470:x:xx::/64 valid-lifetime ‘2592000’
set interfaces ethernet eth1 ipv6 router-advert reachable-time ‘0’
set interfaces ethernet eth1 ipv6 router-advert retrans-timer ‘0’
set interfaces ethernet eth1 ipv6 router-advert send-advert ‘true’
