Randomization of network interfaces
The network interfaces (eth1, eth2,…) on VyOS router are not in the same sequence as network adapters (network adapter 1, network adapter 2,…) on the hypervisor side. I am using e1000 adapters. Any idea why this might be happening and what’s the solution to force OS interfaces to be in same sequence as hypervisor adapters?
Why hypervisor? There’s
You can also set the hw-id on the interfaces to match the hypervisor MAC.
