I have a VyOS router connected to my LAN (eth0) and to two upstream internet providers (eth1 and eth2). It runs pdns-recursor, which is used by the machines on my LAN to resolve DNS.
I recently upgraded from 1.5-stream-2025-Q1 to 1.5-stream-2025-Q2 and I immediately started to see DNS resolution issues on the machines on the LAN. After some troubleshooting, I noticed that I had DNS requests going out through the wrong interface (or with the wrong address). More specifically, I would see packets going out through eth1, but using eth2’s address, and vice versa. Of course, these packets would be ignored by the upstream providers, resulting in DNS timeouts.
The problem is very easy to reproduce by running the following command directly on VyOS:
for N in $(seq 6); do dig enix.fr @4.2.2.$N; done
On 1.5-stream-2025-Q1 all 6 requests get a response immediately.
On 1.5-stream-2025-Q2, requests will randomly timeout.
Interestingly, I ran into this issue when I first deployed VyOS (on 1.5-stream-2025-Q1), and if I remember correctly, I solved it by adding set load-balancing wan enable-local-traffic and by adding a couple of NAT rules. (I don’t know if this was the right decision, so don’t hesitate to point out if there is a better way to do this!)
The relevant configuration snippet is:
load-balancing {
wan {
interface-health eth1 {
nexthop dhcp
interface-health eth2 {
nexthop dhcp
rule 1 {
inbound-interface eth0
interface eth1 {
interface eth2 {
nat {
rule 100 {
outbound-interface {
name eth1
address 10.0.0.0/24
translation {
address masquerade
rule 102 {
name eth1
address 192.168.2.0/24
translation {
address masquerade
rule 200 {
name eth2
address 10.0.0.0/24
translation {
address masquerade
rule 201 {
name eth2
address 192.168.1.0/24
translation {
address masquerade
The problem appeared immediately after I upgraded to 1.5-stream-2025-Q2 and disappeared as soon as I rolled back to 1.5-stream-2025-Q1.
I don’t really need to upgrade to 1.5-stream-2025-Q2 so this is not a big problem for me; but since it seems to be a regression, I thought I’d open a bug report.
