Hello
I am writing using Google Translate.
Please forgive me if it is difficult to read.
If there is anything missing, please let me know.
My Vyos is running on a Lenovo T430 Laptop.
Since version 1.4 (oldest version vyos-1.4-rolling-202108110714 ), the built-in Ethernet is not recognized when using a USB Ethernet adapter.
Here is the log of the problem.
Mar 10 11:40:44 vyos kernel: [ 2.318423] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 28:d2:44:25:9d:44
Mar 10 11:40:44 vyos kernel: [ 2.321731] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
Mar 10 11:40:44 vyos kernel: [ 2.321767] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: 1000FF-0FF
Mar 10 11:40:44 vyos kernel: [ 3.392612] e1000e 0000:00:19.0 e2: renamed from eth0
Mar 10 11:40:44 vyos kernel: [ 17.446788] ax88179_178a 2-1:1.0 eth0: register 'ax88179_178a' at usb-0000:00:14.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:0e:c6:8e:41:84
Mar 10 11:40:45 vyos systemd-udevd[623]: e2: Failed to rename network interface 2 from 'e2' to 'eth0': File exists
Mar 10 11:40:45 vyos systemd-udevd[631]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Mar 10 11:40:45 vyos kernel: [ 18.479731] ax88179_178a 2-1:1.0 eth1: renamed from eth0
It is presumed that it is caused by a name conflict with the USB Ethernet adapter during the rename
process of the built-in Ethernet in the boot log.
The peculiar thing is that the first boot after clean installation recognizes both adapters as shown in the log below.
Mar 10 11:30:21 localhost kernel: [ 2.570543] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 28:d2:44:25:9d:44
Mar 10 11:30:21 localhost kernel: [ 2.572531] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
Mar 10 11:30:21 localhost kernel: [ 2.574006] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: 1000FF-0FF
Mar 10 11:30:21 localhost kernel: [ 3.591914] e1000e 0000:00:19.0 e2: renamed from eth0
Mar 10 11:30:21 localhost kernel: [ 17.354431] ax88179_178a 2-1:1.0 eth0: register 'ax88179_178a' at usb-0000:00:14.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:0e:c6:8e:41:84
Mar 10 11:30:21 localhost kernel: [ 18.430887] ax88179_178a 2-1:1.0 eth1: renamed from eth0
Mar 10 11:30:21 localhost kernel: [ 19.511620] e1000e 0000:00:19.0 eth0: renamed from e2
I’ve seen this issue, but it doesn’t seem to be resolved yet, and it’s a different issue than mine.
More information
vyos@vyos:~$ lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=ax88179_178a, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
vyos@vyos:~$ lspci -tv
-[0000:00]-+-00.0 Intel Corporation 3rd Gen Core processor DRAM Controller
+-02.0 Intel Corporation 3rd Gen Core processor Graphics Controller
+-14.0 Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller
+-16.0 Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1
+-16.2 Intel Corporation 7 Series/C210 Series Chipset Family IDE-r Controller
+-16.3 Intel Corporation 7 Series/C210 Series Chipset Family KT Controller
+-19.0 Intel Corporation 82579LM Gigabit Network Connection (Lewisville)
+-1a.0 Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2
+-1b.0 Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller
+-1c.0-[02]----00.0 Ricoh Co Ltd PCIe SDXC/MMC Host Controller
+-1c.2-[04-0b]--
+-1d.0 Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1
+-1f.0 Intel Corporation QM77 Express Chipset LPC Controller
+-1f.2 Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode]
\-1f.3 Intel Corporation 7 Series/C216 Chipset Family SMBus Controller
vyos@vyos:~$ show version
Version: VyOS 1.4-rolling-202203080319
Release train: sagitta
Built by: autobuild@vyos.net
Built on: Tue 08 Mar 2022 03:19 UTC
Build UUID: 01c39384-2c6e-4e45-9436-33b26290bf68
Build commit ID: b2ca3389494c35
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: LENOVO
Hardware model: 2347D62
Hardware S/N: PBL8V3N
Hardware UUID: b8408801-5296-11cb-b50e-e792f82a4d69
Thanks for reviewing my issue.
