Hello. We have a plan to replace our Mikrotik device into VyOS. Right now the function of the Mikrotik Device is for Traffic Limiter using IP Based Queues in Mikrotik. The queue are graphed into Cacti so our customer can view the bandwidth usage of their services. It is possible to achieve this scenario with VyOS ?
Hello, @harajukakei!
I believe that it is possible to configure queues. But “graphs” part is not very clear. Can you provide an example of such graphs? Also, if you provide queues configuration from MikroTik (export from CLI), we will be able to give you some advises about queue configuration.
Do you have multiple queues (1 per IP)?
As I understand it, each queue is unique in Mikrotik and has its own SNMP-OID.
Cacti get this information via snmp.
All x.x.x.x above is network address that different form one to others.
what i mean about graph is I can get a traffic graph using SNMP that captured into Cacti. So the user can monitor thw bandwidth usage in Cacti. If we using Mikrotik, Cacti can self discover all OID and related stuff about every queue that we created. how we achieve this in VyOS ?
