We have several VyOS VMs running as firewalls in our network, with quite large rulesets that are configured by automated processes. We are thinking in moving to a config-as-code architecture where we would keep each ruleset in a code repository, and push it to the VyOS when there is any change.
I checked which would be the best way to upload and install the ruleset in the VyOS using load/merge, but I find some difficulties:
- Merge: Allows loading a partial config (such as the firewall branch of the config), but it merges with the existing ruleset, doesn’t replace it. If I delete the firewall branch and then merge, I get an error stating that you cannot merge with uncommited changes. This means I would have to do two commits, one for deleting the actual ruleset, and another to load the new one. It would take more time, and would leave the firewall unprotected inbetween.
- Load: Doesn’t seem to support a partial load. If I load a ruleset config file, it deletes the rest of the VyOS config. I would have to do an extra step to merge the ruleset config file from the code repository with a static config file containing the rest of the VyOS config.
At this point, the second option, although not optimal, looks to me like the only feasible way, but I would like to know if somebody else has faced this, or if there are any other options to approach replacing part of a VyOS configuration.
Thanks!
