I’d like to send logs generated by VyOS encrypted to remote servers. I’ve been looking for the configuration in the VyOS side but I don’t find any related to it.
Which is the best way to do it? Thanks in advance
Encryption is not implemented.
There is a feature-request T4251
You could create a wireguard tunnel to the remote server and run the logs over it.
thanks, is it the only way? Is it not possible to send logs to a SSL protected destination port?
Possible but this config is not implemented into CLI yet.
Thanks a lot! I’ll try to use wireguard for it.
