I’m trying to figure how to assign multiple hostnames to a single ip by configuration mode.
I did the following…
set system host-name ‘test-01 test-01.vyos.com mylocalhost’ no-concatenate
Configuration path: system host-name [test-01 test01-vyos.com mylocalhost] is not
valid
Set failed
So, is directly adding new host names in /etc/hosts is the only solution?
to JFL
I’m sorry I don’t have a good answer to your question.
I don’t know in which particular service proxmox servers are needing different names. I’m an at start-level learner for proxmox and sticking to their guide would surely save future troubles.
Anyhow, returning to the vyos configuration mode, is it odd that set no-concatenate doesn’t work for setting multiple hostnames? If someone have already managed, please kindly advice.
This is actually a bad idea to add proxmox on top of vyos.
you will break many things during updates of either system.
Just run vyos in a VM on proxmox, I did it for a long time until I finally got my Edge Router Lite.
PS. You don’t actually need multiple hostnames. The instructions just tell you that you need the ability to RESOLVE by hostname. It does not mean you need multiples.
Thank you for your advise pirateghost.
I will set up a clean proxmox server later.
But for now my motivation is to know what vyos config mode can do and cannot do.
So, is there a way to write multiple hostnames through config mode? or only by way of directly changing /etc/hosts.
