Hi
I want to setup a site to site dmvpn on 1.2.0 rc10.
In the spock site used pppoe over nat connect to internet.
in the hub site used static public IP connect to Internet.
the Vyos setup follow information
Hub Site setup:(ver 1.2.0 rc10)
address 116.90.86.181/24
duplex auto
hw-id 00:50:56:95:6e:1a
smp-affinity auto
speed auto
address 172.16.101.1/24
duplex auto
hw-id 00:50:56:95:8e:c3
smp-affinity auto
speed auto
loopback lo {
tunnel tun0 {
address 10.0.0.1/24
encapsulation gre
local-ip 116.90.86.181
multicast enable
parameters {
ip {
key 1
nhrp {
tunnel tun0 {
cisco-authentication
holding-time 300
multicast dynamic
redirect
static {
route 0.0.0.0/0 {
next-hop 116.90.86.254 {
route 192.168.101.0/24 {
next-hop 10.0.0.2 {
ipsec {
esp-group ESP-HUB {
compression disable
lifetime 1800
mode tunnel
pfs dh-group2
proposal 1 {
encryption aes256
hash sha256
proposal 2 {
encryption 3des
hash md5
ike-group IKE-HUB {
ikev2-reauth no
key-exchange ikev1
lifetime 3600
proposal 1 {
dh-group 2
encryption aes256
hash sha1
proposal 2 {
dh-group 2
encryption aes128
hash sha1
ipsec-interfaces {
interface eth0
nat-traversal enable
profile IDC-VPN {
authentication {
mode pre-shared-secret
pre-shared-secret
bind {
tunnel tun0
esp-group ESP-HUB
ike-group IKE-HUB
And Spock Site setup (ver 1.2.0 rc10)
duplex auto
hw-id 00:e0:67:08:81:44
pppoe 0 {
default-route auto
mtu 1492
name-server auto
password xxx
user-id xxx
smp-affinity auto
speed auto
duplex auto
hw-id 00:e0:67:08:81:45
smp-affinity auto
speed auto
ethernet eth2 {
duplex auto
hw-id 00:e0:67:08:81:46
smp-affinity auto
speed auto
ethernet eth3 {
address 192.168.101.1/24
duplex auto
hw-id 00:e0:67:08:81:47
smp-affinity auto
speed auto
loopback lo {
tunnel tun0 {
address 10.0.0.2/24
encapsulation gre
local-ip 0.0.0.0
multicast enable
parameters {
ip {
key 1
nhrp {
tunnel tun0 {
map 10.0.0.1/24 {
nbma-address 116.90.86.181
register
multicast nhs
redirect
shortcut
static {
route 172.16.101.0/24 {
next-hop 10.0.0.1 {
ipsec {
esp-group ESP-SPOKE {
compression disable
lifetime 1800
mode tunnel
pfs dh-group2
proposal 1 {
encryption aes256
hash sha256
proposal 2 {
encryption 3des
hash md5
ike-group IKE-SPOKE {
ikev2-reauth no
key-exchange ikev1
lifetime 3600
proposal 1 {
dh-group 2
encryption aes256
hash sha1
proposal 2 {
dh-group 2
encryption aes128
hash sha1
ipsec-interfaces {
interface pppoe0
profile IDC-ZZ {
authentication {
pre-shared-secret
bind {
tunnel tun0
esp-group ESP-SPOKE
ike-group IKE-SPOKE
I check log see follow info
In Hub show log all | grep charon
Dec 9 13:02:00 vyos charon: 08[ENC] generating INFORMATIONAL_V1 request 3953897240 [ HASH N(INVAL_ID) ]
Dec 9 13:02:00 vyos charon: 08[NET] sending packet: from 116.90.86.181[4500] to 115.60.57.13[23132] (76 bytes)
Dec 9 13:04:57 vyos charon: 10[NET] received packet: from 115.60.57.13[23132] to 116.90.86.181[4500] (92 bytes)
Dec 9 13:04:57 vyos charon: 10[ENC] parsed INFORMATIONAL_V1 request 1310358166 [ HASH D ]
Dec 9 13:04:57 vyos charon: 10[IKE] received DELETE for IKE_SA vpnprof-dmvpn-tun0[116]
Dec 9 13:04:57 vyos charon: 10[IKE] deleting IKE_SA vpnprof-dmvpn-tun0[116] between 116.90.86.181[116.90.86.181]…115.60.57.13[100.64.21.35]
Dec 9 13:04:57 vyos charon: 14[NET] received packet: from 115.60.57.13[21532] to 116.90.86.181[500] (216 bytes)
Dec 9 13:04:57 vyos charon: 14[ENC] parsed ID_PROT request 0 [ SA V V V V V ]
Dec 9 13:04:57 vyos charon: 14[IKE] received XAuth vendor ID
Dec 9 13:04:57 vyos charon: 14[IKE] received DPD vendor ID
Dec 9 13:04:57 vyos charon: 14[IKE] received FRAGMENTATION vendor ID
Dec 9 13:04:57 vyos charon: 14[IKE] received NAT-T (RFC 3947) vendor ID
Dec 9 13:04:57 vyos charon: 14[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Dec 9 13:04:57 vyos charon: 14[IKE] 115.60.57.13 is initiating a Main Mode IKE_SA
Dec 9 13:04:57 vyos charon: 14[ENC] generating ID_PROT response 0 [ SA V V V V ]
Dec 9 13:04:57 vyos charon: 14[NET] sending packet: from 116.90.86.181[500] to 115.60.57.13[21532] (160 bytes)
Dec 9 13:04:57 vyos charon: 15[NET] received packet: from 115.60.57.13[21532] to 116.90.86.181[500] (244 bytes)
Dec 9 13:04:57 vyos charon: 15[ENC] parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Dec 9 13:04:57 vyos charon: 15[IKE] remote host is behind NAT
Dec 9 13:04:57 vyos charon: 15[ENC] generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Dec 9 13:04:57 vyos charon: 15[NET] sending packet: from 116.90.86.181[500] to 115.60.57.13[21532] (244 bytes)
Dec 9 13:04:57 vyos charon: 13[NET] received packet: from 115.60.57.13[23132] to 116.90.86.181[4500] (76 bytes)
Dec 9 13:04:57 vyos charon: 13[ENC] parsed ID_PROT request 0 [ ID HASH ]
Dec 9 13:04:57 vyos charon: 13[CFG] looking for pre-shared key peer configs matching 116.90.86.181…115.60.57.13[100.64.21.35]
Dec 9 13:04:57 vyos charon: 13[CFG] selected peer config “vpnprof-dmvpn-tun0”
Dec 9 13:04:57 vyos charon: 13[IKE] IKE_SA vpnprof-dmvpn-tun0[117] established between 116.90.86.181[116.90.86.181]…115.60.57.13[100.64.21.35]
Dec 9 13:04:57 vyos charon: 13[IKE] scheduling rekeying in 3588s
Dec 9 13:04:57 vyos charon: 13[IKE] maximum IKE_SA lifetime 3948s
Dec 9 13:04:57 vyos charon: 13[ENC] generating ID_PROT response 0 [ ID HASH ]
Dec 9 13:04:57 vyos charon: 13[NET] sending packet: from 116.90.86.181[4500] to 115.60.57.13[23132] (76 bytes)
Dec 9 13:04:57 vyos charon: 07[NET] received packet: from 115.60.57.13[23132] to 116.90.86.181[4500] (332 bytes)
Dec 9 13:04:57 vyos charon: 07[ENC] parsed QUICK_MODE request 614827736 [ HASH SA No KE ID ID ]
Dec 9 13:04:57 vyos charon: 07[IKE] no matching CHILD_SA config found
In Spock site show log all | grep charon
Dec 9 13:05:13 vyos charon: 07[CFG] vici terminate with source me 100.64.21.35 and other 116.90.86.181
Dec 9 13:05:13 vyos charon: 06[IKE] deleting IKE_SA vpnprof-dmvpn-tun0[38] between 100.64.21.35[100.64.21.35]…116.90.86.181[116.90.86.181]
Dec 9 13:05:13 vyos charon: 06[IKE] sending DELETE for IKE_SA vpnprof-dmvpn-tun0[38]
Dec 9 13:05:13 vyos charon: 06[ENC] generating INFORMATIONAL_V1 request 1310358166 [ HASH D ]
Dec 9 13:05:13 vyos charon: 06[NET] sending packet: from 100.64.21.35[4500] to 116.90.86.181[4500] (92 bytes)
Dec 9 13:05:13 vyos charon: 06[CFG] vici initiate ‘dmvpn’, me 100.64.21.35, other 116.90.86.181, limits 0
Dec 9 13:05:13 vyos charon: 07[IKE] initiating Main Mode IKE_SA vpnprof-dmvpn-tun0[39] to 116.90.86.181
Dec 9 13:05:13 vyos charon: 07[ENC] generating ID_PROT request 0 [ SA V V V V V ]
Dec 9 13:05:13 vyos charon: 07[NET] sending packet: from 100.64.21.35[500] to 116.90.86.181[500] (216 bytes)
Dec 9 13:05:13 vyos charon: 05[NET] received packet: from 116.90.86.181[500] to 100.64.21.35[500] (160 bytes)
Dec 9 13:05:13 vyos charon: 05[ENC] parsed ID_PROT response 0 [ SA V V V V ]
Dec 9 13:05:13 vyos charon: 05[IKE] received XAuth vendor ID
Dec 9 13:05:13 vyos charon: 05[IKE] received DPD vendor ID
Dec 9 13:05:13 vyos charon: 05[IKE] received FRAGMENTATION vendor ID
Dec 9 13:05:13 vyos charon: 05[IKE] received NAT-T (RFC 3947) vendor ID
Dec 9 13:05:13 vyos charon: 05[ENC] generating ID_PROT request 0 [ KE No NAT-D NAT-D ]
Dec 9 13:05:13 vyos charon: 05[NET] sending packet: from 100.64.21.35[500] to 116.90.86.181[500] (244 bytes)
Dec 9 13:05:13 vyos charon: 07[NET] received packet: from 116.90.86.181[500] to 100.64.21.35[500] (244 bytes)
Dec 9 13:05:13 vyos charon: 07[ENC] parsed ID_PROT response 0 [ KE No NAT-D NAT-D ]
Dec 9 13:05:13 vyos charon: 07[IKE] local host is behind NAT, sending keep alives
Dec 9 13:05:13 vyos charon: 07[ENC] generating ID_PROT request 0 [ ID HASH ]
Dec 9 13:05:13 vyos charon: 07[NET] sending packet: from 100.64.21.35[4500] to 116.90.86.181[4500] (76 bytes)
Dec 9 13:05:13 vyos charon: 13[NET] received packet: from 116.90.86.181[4500] to 100.64.21.35[4500] (76 bytes)
Dec 9 13:05:13 vyos charon: 13[ENC] parsed ID_PROT response 0 [ ID HASH ]
Dec 9 13:05:13 vyos charon: 13[IKE] IKE_SA vpnprof-dmvpn-tun0[39] established between 100.64.21.35[100.64.21.35]…116.90.86.181[116.90.86.181]
Dec 9 13:05:13 vyos charon: 13[IKE] scheduling rekeying in 3304s
Dec 9 13:05:13 vyos charon: 13[IKE] maximum IKE_SA lifetime 3664s
Dec 9 13:05:13 vyos charon: 13[ENC] generating QUICK_MODE request 614827736 [ HASH SA No KE ID ID ]
Dec 9 13:05:13 vyos charon: 13[NET] sending packet: from 100.64.21.35[4500] to 116.90.86.181[4500] (332 bytes)
Dec 9 13:05:13 vyos charon: 04[NET] received packet: from 116.90.86.181[4500] to 100.64.21.35[4500] (76 bytes)
Dec 9 13:05:13 vyos charon: 04[ENC] parsed INFORMATIONAL_V1 request 3550378600 [ HASH N(INVAL_ID) ]
Dec 9 13:05:13 vyos charon: 04[IKE] received INVALID_ID_INFORMATION error notify
Please help me fix it
Thanks
David
