Hello friends, how are you?
I’m using VyOS 1.1.8, normally, but some days, the SSH connection is failluring, reporting this message on Putty, and changing SSH client, same error:
Network error: Network error: Software caused connection abort
And I can’t connect on VyOS. So, how can we fix this issue? If reboot VyOS, the ssh connection be ready, but after some days, blocked again. I checked and had a subnet (customer) that had static loop, but don’t have more, this issue.
Thank you so much,
With Best Regards
Josue
