So had one VyOS 1.2 device and just replaced it with 2 VyOS 1.2.5 devices, sharing an IP over VRRP. Works great, with one exception: I added a static route to access another site via a VPN box, and I can ping things at the other site from VyOS itself, but not across it / not from any machine it’s connected to.
Any help would be very much appreciated! Thanks!!
Hi darkhelmet,
From the side you cannot reach what does the routing table look like? Can you share configs?
Hi Ocosa - thanks for your reply. Here is the config:
vyos@vyos:~$ show config
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name LAN-LOCAL {
default-action accept
name LAN-WAN {
name LOCAL-LAN {
name LOCAL-WAN {
name WAN-LAN {
default-action drop
rule 5 {
action accept
description “Allow EST/Related Traffic”
state {
established enable
related enable
rule 20 {
action accept
protocol icmp
state {
new enable
name WAN-LOCAL {
default-action drop
rule 5 {
action accept
state {
established enable
related enable
rule 20 {
action accept
protocol icmp
state {
new enable
send-redirects enable
source-validation disable
syn-cookies enable
high-availability {
vrrp {
group LAN {
interface eth3
priority 2
virtual-address 10.x.x.x/24
vrid 100
group WAN1 {
interface eth4
priority 2
virtual-address [wan1 address]/24
vrid 101
group WAN2 {
interface eth2
priority 2
virtual-address [wan2 address]/29
vrid 102
sync-group MAIN {
member LAN
member WAN1
member WAN2
ethernet eth2 {
description WAN2
duplex auto
hw-id [mac address]
smp-affinity auto
speed auto
ethernet eth3 {
address 10.x.x.x/24
description LAN
hw-id [mac address]
ethernet eth4 {
description WAN
hw-id [mac address]
loopback lo {
load-balancing {
wan {
flush-connections
interface-health eth2 {
nexthop [wan2 gateway]
interface-health eth4 {
nexthop [wan1 gateway]
rule 1 {
failover
inbound-interface eth3
interface eth2 {
interface eth4 {
sticky-connections {
inbound
nat {
rule 100 {
outbound-interface eth4
address 10.0.0.0/16
translation {
address masquerade
rule 101 {
outbound-interface eth2
address 10.0.0.0/16
translation {
address masquerade
protocols {
static {
route 0.0.0.0/0 {
next-hop [wan2 gateway] {
next-hop [wan1 gateway] {
route 10.0.x.0/24 {
next-hop 10.0.x.x {
route 10.0.x.0/24 {
next-hop 10.0.x.x {
route 10.0.x.0/24 {
next-hop 10.0.x.x {
route 10.0.x.0/24 {
next-hop 10.0.x.x {
route 10.x.x.0/24 {
next-hop 10.0.x.x {
service {
ssh {
port 22
system {
config-management {
commit-revisions 100
console {
device ttyS0 {
speed 9600
host-name vyos
login {
user vyos {
authentication {
level admin
name-server 10.0.x.x
ntp {
server x {
server x {
server x {
syslog {
global {
facility all {
level info
facility protocols {
level debug
time-zone UTC
zone-policy {
zone LAN {
default-action drop
from LOCAL {
firewall {
name LOCAL-LAN
from WAN {
firewall {
name WAN-LAN
interface eth0
interface eth3
zone LOCAL {
default-action drop
from LAN {
firewall {
name LAN-LOCAL
from WAN {
firewall {
name WAN-LOCAL
local-zone
zone WAN {
default-action drop
from LAN {
firewall {
name LAN-WAN
from LOCAL {
firewall {
name LOCAL-WAN
interface eth1
interface eth2
interface eth4
