System package in VyOS 1.2.0 rolling
Hello.
Was feature for adding repos removed from 1.2?
VyOS 1.1.8
set system package exists,
but in VyOS 1.2.0-rolling+201903050337 this does not exist.
Yes, it is intentionally removed because the vyos team don’t want to courage you to install custom packages. But you are welcome to modify the apt files in /etc yourself, but it is not officially supported… :slight_smile: remember that after a system image upgrade all customization of any filesystem except /config and custom package installations need to be done once again…
Thanks for the answer.
