Hi, I think you need to try to set it with DHCP Server options for different networks, if I understand you properly
set service dhcp-server shared-network-name lan.net subnet 192.168.1.0/24 domain-name lan.net
set service dhcp-server shared-network-name storage.net subnet 172.16.1.0/24 domain-name storage.net
Although, I don’t want to run a dhcp server on VyOS for lan.net, so I’m guessing I should make lan.net my system’s search domain, and storage.net my dhcp shared-network-name (?)
I do plan to have VyOS hand out IPs on storage.net, but I don’t intend to NAT between the two. storage.net will be entirely separate, and only available to VMs that have another vNIC attached to that network.
Edit: Additionally, I’d like VyOS to serve as a rudimentary DNS, is static-host-mapping what I’m looking for? Entering each name manually is entirely fine.
