Is it possible to use the same procedure to upgrade to 1.2?
https://wiki.vyos.net/wiki/Upgrade
Thanks,
Thanks,
Also really interesting about the update procedure.
As there are some syntax changes,
Do they get converted or how does that works?
I can share my experiences with the AMI othe AWS Markplace. Something seems to break with SSH keys in the 1.8 to 1.2RCx upgrade. I could no longer access the EC2 instance. I can upgrade successfully from 1.2RCx to another 1.2RCx.
I have done the upgrade from 1.1.8 to 1.2.0-RC10 without any issues.
SSH Keys still working and the DHCP config where the syntax have changed got translated to the new syntax.
