We use a lot of community edition vyatta with verion 6.1 and 6.6 , can we migrate/upgrade the same to vyos.
pl. share any link for the upgrade process
Regards
senthil
Regards
senthil
I have replaced some vyatta 6.x systems with vyos, and it went smoothly. I just save the config file from the old system, and copy/paste it back into new system. Some of the config commands dealing with firewalls changed between 6.1 and 6.6. Vyos syntax should be compatible with vyatta 6.6.
As always, test it in your environment before updating production systems.
