Hi All, I am planing to create vxlan tunnel over IPsec. Is it possible that the vyos vm where vxlan tunnel ends can work as proxy arp and does not send arp request over the vxlan tunnel?
Hi, I think this is possible. Can you draw a network map? Maybe in this case you need do bridging vxlan
and ethX
