I have faced a situation today, I am trying “add system image /etc/ulak/vyos-1.2.iso” command with existing iso file, but the response is shown as below.
"Help:
–username use username for HTTP auth (optional)
–password use password for HTTP auth (optional)
I looked commits, I guess, there is a bug occured after commit “771e535725cee0c01a80a71717afce85d7efcc70”. Because I can use this command before the pull updated repositories. Maybe I miss something about using this command. Any idea or suggestion? Thanks
Hello @utosun, I did not get this issue on the latest rolling.
vyos@vyos:~$ show version | match Version
Version: VyOS 1.3-rolling-202008070118
vyos@vyos:~$ curl https://downloads.vyos.io/rolling/current/amd64/vyos-1.3-rolling-202008040823-amd64.iso -O
vyos@vyos:~$ ls
vyos@vyos:~$ add system image /home/vyos/vyos-1.3-rolling-202008040823-amd64.iso
Checking MD5 checksums of files on the ISO image...OK.ing-202008040823-amd64.iso
Done!
What would you like to name this image? [1.3-rolling-202008040823]:
OK. This image will be named: 1.3-rolling-202008040823
Installing "1.3-rolling-202008040823" image.
Copying new release files...
Would you like to save the current configuration
directory and config file? (Yes/No) [Yes]:
Copying current configuration...
Would you like to save the SSH host keys from your
current configuration? (Yes/No) [Yes]:
Copying SSH keys...
Running post-install script...
Setting up grub configuration...
Done.
