VYOS 1.2.RC5-AMD64 WAN Load Balancing - The clients can not open webpage
Dear all,
I have vyatta/vyos for a few years, it always work perfectly when it handle only one PPPOE connection or DSL static connection.
Now I have two pppoe connection from ISP, and I want to make it work together. So I did set the load balancing to check it and it doesn’t work.
The clients only can ping the website ip address, they can’t open the website. I am sure this is not DNS problem. (It can work perfectly when I change it on one PPPoE connection)
Could anyone help me to fix the problem? Thank you very much!
Below is the config code:
vyos@vyos# run show ip route
F - PBR, f - OpenFabric,
> - selected route, * - FIB route
K>* 0.0.0.0/0 [0/0] is directly connected, pppoe3, 00:29:05
C>* 100.64.0.1/32 is directly connected, pppoe3, 00:29:05
C>* 113.109.160.1/32 is directly connected, pppoe1, 00:29:02
S>* 114.114.114.114/32 [1/0] is directly connected, pppoe1, 00:04:51
  *                          is directly connected, pppoe3, 00:04:51
C>* 192.168.0.0/20 is directly connected, eth0, 00:29:04
vyos@vyos# run show wan-load-balance
Interface:  pppoe1
  Status:  active
  Last Status Change:  Wed Oct 31 12:52:08 2018
  +Test:  ping  Target: 114.114.114.114
    Last Interface Success:  0s
    Last Interface Failure:  n/a
    # Interface Failure(s):  0
Interface:  pppoe3
  Status:  active
vyos@vyos# show int
     address 192.168.0.176/20
     duplex auto
     hw-id 92:fd:26:c7:a3:12
     policy {
         route pppoeOut
     smp-affinity auto
     speed auto
 ethernet eth5 {
     duplex auto
     hw-id ba:13:86:6e:cb:ac
     pppoe 1 {
         default-route auto
         mtu 1492
         name-server auto
         password 'xxxxxxx'
         user-id 'xxxxxxxx'
     smp-affinity auto
     speed auto
 ethernet eth6 {
     duplex auto
     hw-id 9e:48:71:a5:dd:37
     pppoe 3 {
         default-route auto
         mtu 1492
         name-server auto
         password 'xxxxxx'
         user-id 'xxxxxxxx'
     smp-affinity auto
     speed auto
vyos@vyos# show policy
 route pppoeOut {
     rule 1 {
         protocol tcp
         set {
             tcp-mss 1452
         tcp {
             flags SYN
vyos@vyos# show nat
     rule 1 {
         outbound-interface pppoe1
         translation {
             address masquerade
     rule 3 {
         outbound-interface pppoe3
         translation {
             address masquerade
 vyos@vyos# show load-balancing
wan {
     flush-connections
     interface-health pppoe1 {
         failure-count 1
         nexthop dhcp
         success-count 1
         test 1 {
             resp-time 5
             target 114.114.114.114
             ttl-limit 1
			 type ping
     interface-health pppoe3 {
         failure-count 1
         nexthop dhcp
         success-count 1
         test 1 {
             resp-time 5
             ttl-limit 1
			 type ping
     rule 1 {
         inbound-interface eth0
         interface pppoe1 {
             weight 10
         interface pppoe3 {
             weight 10
         protocol all
Hello, @coolvir!
Show, please, output of next commands:
ip l
ip r
ip left:eth0 (lan)
ip right:eth5(pppoe1),eth6(pppoe3)
and now it looks can ping everywhere,but still can not open the website.
I did try to setup 3 vyos system to check it (each 2 vyos point to each 2 ISP pppoe connection, and the third vyos setup three interface and route by other 2 vyos.), and I found it work normally.
Maybe the problem is policy route of the interface?Who can tell me why and how to fix the problem?
I am very sorry I miss it " [[solved] WAN load-balancing with policy route rules [previously: WAN load-balancing" in forum, But the method looks like ‘hack script’, Does the offical have the better solution?
Hello, @coolvir! I have mean ip link and ip route commands. :slightly_smiling_face: Example:
vyos@vyos:~$ ip l
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether 08:00:27:4b:33:e5 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether 08:00:27:01:da:89 brd ff:ff:ff:ff:ff:ff
4: eth2: <BROADCAST,MULTICAST> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
    link/ether 08:00:27:2d:07:cb brd ff:ff:ff:ff:ff:ff
vyos@vyos:~$ ip r
default via 10.0.2.2 dev eth0 proto static metric 20
10.0.2.0/24 dev eth0 proto kernel scope link src 10.0.2.5
192.168.20.0/24 dev eth1 proto kernel scope link src 192.168.20.60
Can you show your output of this commands?
I found the problem that is the policy route can not work on dual pppoe wan load balancing,do you have any better solution?
@coolvir The simplest solution is to balance based on a connection mark and not based on a packet.
There are couple approaches to this but the naive one is to use a “round robin” like algorithm which iptables will mark at prerouting for ingress traffic from the LAN.
To loadbalance the traffic from the VyOS machine itself I believe the settings would be a bit different.
I know how to set it all up using plain linux and iptables but not in VyOS.
It can work with dual pppoe connections
Thanks for your reply, Could you write down your config commands ? I think it can help a lot of people.
@coolvir if @syncer or @dmbaturin will not be able to answer faster then me I will try to see how it should be done on vyos.
edit:
@coolvir have you tried looking at: Load-balancing — VyOS 1.4.x (sagitta) documentation
Thank you very much for taking the time to reply, I wish this product more and more popular, thanks you for your efforts.
Hi elico,
I did try to set up load balancing by per packet mode and it not work.
@coolvir You need per flow not per packet.
In a per packet mode the syn will transmitted from one src IP while the syn-ack or ack or any other packet in the sequence will have different src IP.
Have you tried per flow?
