I am using currently built 1.3 iso from current branch. In my tests, I faced a problem which defined step by step in below;
1- Set new vif 111 in an interface eth0
set interfaces ethernet eth0 vif 111 address 9.9.9.9/24 (in conf mode)
2- Check “show interfaces” result in conf mode and op mode. Results are same as expected.
3- Then, delete defined vif with this command (in conf mode)
del interfaces ethernet eth0 vif 111
4- After this delete operation the result of “show interfaces” in conf mode and op mode are shown different. Also when I look interfaces with “ifconfig”, I continue to see deleted vlan within results.
I guess that it is bug of 1.3 release. Otherwise please inform me what is my mistake ?
Thanks.
