Vyos 1.4 reboot error
I have this error message every time I reboot my vyos:
Nov 22 15:17:59 T6p-DYJIX-Edge01 systemd[1]: Failed unmounting /usr/lib/live/mount/persistence.
Nov 22 15:17:59 T6p-DYJIX-Edge01 systemd[1]: Reached target Unmount All Filesystems.
I have to unplug it electrically and plug it back in.
Have you ever seen this problem.
Thank you in advance.
Hi, can you enter recovery mode?
Thank you for taking the time to answer me, I can’t test before Monday morning, I’ll get back to you.
Yes, I can enter recovery mode,
To test I reinstalled the OS, but I still have the same problem, below the error message on restart:
[ OK ] Unmounted boot.mount.
[FAILED] Failed unmounting usr-lib-…- /usr/lib/live/mount/persistence.
[ OK ] Stopped [email protected] - DHCP client on eth5.
[ OK ] Removed slice system-dhcli…lice - Slice /system/dhclient.
[ OK ] Stopped frr.service - FRRouting.
[ OK ] Stopped target basic.target - Basic System.
[ OK ] Stopped target paths.target - Path Units.
[ OK ] Stopped acpid.path - ACPI Events Check.
[ OK ] Stopped systemd-ask-passwo…quests to Console Directory Watch.
[ OK ] Stopped systemd-ask-passwo… Requests to Wall Directory Watch.
[ OK ] Stopped target slices.target - Slice Units.
[ OK ] Removed slice user.slice - User and Session Slice.
[ OK ] Stopped target sockets.target - Socket Units.
[ OK ] Closed acpid.socket - ACPID Listen Socket.
[ OK ] Closed dbus.socket - D-Bus System Message Bus Socket.
[ OK ] Closed podman.socket - Podman API Socket.
[ OK ] Closed syslog.socket - Syslog Socket.
[ OK ] Closed uuidd.socket - UUID daemon activation socket.
Unmounting tmp.mount - /tmp…
Unmounting var-tmp.mount - /var/tmp…
[ OK ] Stopped systemd-sysctl.service - Apply Kernel Variables.
[ OK ] Stopped systemd-modules-lo…service - Load Kernel Modules.
[ OK ] Unmounted tmp.mount - /tmp.
[ OK ] Unmounted var-tmp.mount - /var/tmp.
[ OK ] Stopped target local-fs-pr…reparation for Local File Systems.
[ OK ] Stopped target swap.target - Swaps.
[ OK ] Reached target umount.target - Unmount All Filesystems.
[ OK ] Stopped systemd-tmpfiles-s…reate Static Device Nodes in /dev.
[ OK ] Stopped systemd-sysusers.service - Create System Users.
[ OK ] Stopped systemd-remount-fs…ount Root and Kernel File Systems.
[ OK ] Reached target shutdown.target - System Shutdown.
[ OK ] Reached target final.target - Late Shutdown Services.
[ OK ] Finished systemd-poweroff.service - System Power Off.
[ OK ] Reached target poweroff.target - System Power Off.
[ 105.195777] (sd-umount)[3549]: Failed to unmount /usr/lib/live/mount/persistence: Device or resource busy
[ 105.208348] systemd-shutdown[1]: Could not detach loopback /dev/loop0: Device or resource busy
[ 105.285786] systemd-shutdown[1]: Failed to finalize file systems, loop devices, ignoring.
[ 106.503060] reboot: Power down
Thank you.
