Labbing a DMVPN Network, I am able to establish full communication between VyOS(1.4-rolling) Hub and Spoke routers. My problem is a Cisco spoke, I keep getting a “CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at 172.16.120.101” message. I’m new to ipsec and I’m not sure if I am just misreading some part of this config guide. I would appreciate any insight into my problem.
Thank You!
Hub: WAN(172.16.120.101) Tunnel(10.0.0.1/29)
Vyos Spoke: WAN(172.16.120.104) Tunnel(10.0.0.2/29)
Cisco Spoke: WAN(172.16.120.102) Tunnel(10.0.0.3/29)
!!!HUB Config!!!
set interfaces tunnel tun0 address ‘10.0.0.1/29’
set interfaces tunnel tun0 multicast ‘enable’
set interfaces tunnel tun0 parameters ip key ‘1’
set interfaces tunnel tun0 source-address ‘172.16.120.101’
set protocols nhrp tunnel tun0 cisco-authentication ‘secret’
set protocols nhrp tunnel tun0 holding-time ‘300’
set protocols nhrp tunnel tun0 multicast ‘dynamic’
set protocols nhrp tunnel tun0 redirect
set protocols nhrp tunnel tun0 shortcut
set vpn ipsec interface ‘eth1’
set vpn ipsec esp-group ESP-DMVPN compression ‘disable’
set vpn ipsec esp-group ESP-DMVPN lifetime ‘1800’
set vpn ipsec esp-group ESP-DMVPN mode ‘transport’
set vpn ipsec esp-group ESP-DMVPN pfs ‘dh-group2’
set vpn ipsec esp-group ESP-DMVPN proposal 1 encryption ‘aes256’
set vpn ipsec esp-group ESP-DMVPN proposal 1 hash ‘sha1’
set vpn ipsec ike-group IKE-DMVPN ikev2-reauth ‘no’
set vpn ipsec ike-group IKE-DMVPN key-exchange ‘ikev1’
set vpn ipsec ike-group IKE-DMVPN lifetime ‘3600’
set vpn ipsec ike-group IKE-DMVPN proposal 1 dh-group ‘2’
set vpn ipsec ike-group IKE-DMVPN proposal 1 encryption ‘aes256’
set vpn ipsec ike-group IKE-DMVPN proposal 1 hash ‘sha1’
set vpn ipsec profile NHRPVPN authentication mode ‘pre-shared-secret’
set vpn ipsec profile NHRPVPN authentication pre-shared-secret ‘secret’
set vpn ipsec profile NHRPVPN bind tunnel ‘tun0’
set vpn ipsec profile NHRPVPN esp-group ‘ESP-DMVPN’
set vpn ipsec profile NHRPVPN ike-group ‘IKE-DMVPN’
!!!Cisco Spoke!!!
crypto keyring DMVPN
pre-shared-key address 172.16.120.101 key secret
crypto isakmp policy 10
encr aes 256
group 2
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 30 30 periodic
crypto isakmp profile DMVPN
keyring DMVPN
match identity address 172.16.120.101 255.255.255.255
crypto ipsec transform-set DMVPN-AES256 esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec profile DMVPN
set security-association idle-time 720
set transform-set DMVPN-AES256
set isakmp-profile DMVPN
interface Tunnel10
ip address 10.0.0.3 255.255.255.248
no ip redirects
ip nhrp authentication secret
ip nhrp map 10.0.0.1 172.16.120.101
ip nhrp map multicast 172.16.120.101
ip nhrp network-id 1
ip nhrp holdtime 600
ip nhrp nhs 10.0.0.1
ip nhrp registration timeout 75
tunnel source F1/0
tunnel mode gre multipoint
tunnel key 1
tunnel protection ipsec profile DMVPN
!!!Vyos Spoke!!!
set interfaces tunnel tun0 address ‘10.0.0.2/29’
set interfaces tunnel tun0 source-address ‘0.0.0.0’
set protocols nhrp tunnel tun0 map 10.0.0.1 nbma-address ‘172.16.120.101’
set protocols nhrp tunnel tun0 map 10.0.0.1 register
set protocols nhrp tunnel tun0 multicast ‘nhs’
