Ok heres the deal and I hope from the info I supply can assist me with my dilemma its real life
Im having to figure out something thrown at me and never used vyos before, hopefully someone can assist.
I have vm workstation 12 with several vm’s on it that need to be networked together on 3 separate networks and be able to go out to the internet…
I am in a virtual machine which is running workstation which all the builds re3side to be more precise…
the gateway to internet out is 10.0.0.254 and the vm is 10.0.0.1 ( this is the vm housing all the others on workstation nested as well as VYOS )
so I will need three networks within work station lets say eth3, eth4, and eth5
I ve done some reading on it and I know some say bridged, some say nat, some say dhcp…(which this is not ) all will be static addresses -
Im a bit mind boggled here and could use some direction because of this weird design…
Workstation - VYOS router, win8, win2008 server, and centos, another windows web server , internal os and external os - pheew ( all with three networks ) and must
- all be able to get out to the internet via VYOS and also be on three 3 separate networks.
I hopw this explains my dilemma and is enough info for someone to assist me in doing this task…
My thanks in advance to all who will contribute…
