Hello everyone
I enabled today new router to vyos but i lived issues
1-) i can reach maximum 200-600mbps aversge on iperf3 test through vyos
2-3 network down for 2-3 seconda every 30-40 seconds and have packet loss
I tried;
Set mtu 9000
Set disable-flow-comtrol
Check interfaces trafic atatiatic but dont have dropped packets 0
And when i commit interface settings i getting this error
could not set flowcontrol for eth3
could not set flowcontrol for eth2
Interface detail eth3 — WAN
Note: ı tested iperf3 on vyos
Hardware details
2x - X5690 processor
64gb ram
Intel x520-da2 network adapters
10g MM Mikrotik gbic (tested on my main router dont have any problem i can reach 10g/10g traffic and network adapter too
I will try on 9900k cpu atx server for vyos after 5-6 days
I can not test any for now because i disabled vyos on my network for this issue
vyos@vyos:~$ show interfaces ethernet eth3 physical
Settings for eth3:
Supported ports: [ FIBRE ]
Supported link modes: 10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Supported FEC modes: Not reported
Advertised link modes: 10000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
driver: ixgbe
version: 5.10.39-amd64-vyos
firmware-version: 0x00012b2c, 1.1197.0
expansion-rom-version:
bus-info: 0000:1a:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Interface detail eth2 - LAN
vyos@vyos:~$ show interfaces ethernet eth2 physical
Settings for eth2:
Speed: Unknown!
Duplex: Unknown! (255)
Port: FIBRE
PHYAD: 0
Supports Wake-on: d
Wake-on: d
drv probe link
Link detected: no
driver: ixgbe
bus-info: 0000:1a:00.0
supports-test: yes
