vyos ping-timeout/ssh-lost after config script execution
Environment : OpenStack Juno
Image : VyOS 1.1.7
Issue : I have a script to just set hostname (& other basic stuff) on VyOS, created using http://vyos.net/wiki/Configuration_scripting. Once I execute the script, the remote ssh connection is lost and ping starts dropping intermittently.
Please let me know what might be happening here
Observation:
  1. Same is not seen if VyOS is just created on plain KVM on Ubuntu 14.04.01.
  2. VyOS was installed using ‘install image’.
  3. 3,879,088k memory is free out of total 4,054,688 k in top.
  4. cpu is 99.8% idle in top.
Steps Tried :
  1. Changed glance image hw_vif_model to virtio/e1000/rtl8139 without luck.
  2. Tried cli-shell-api without luck.
SCRIPT 1:
#!/bin/vbash
configure
set system host-name TEST
commit
SCRIPT 2:
#!/bin/bash
WRAPPER=/opt/vyatta/sbin/vyatta-cfg-cmd-wrapper
$WRAPPER begin
$WRAPPER set system host-name TEST
$WRAPPER set interfaces loopback lo address 1.1.1.1/32
$WRAPPER set system ntp server 8.8.8.8
$WRAPPER set system name-server 8.8.8.8
$WRAPPER commit
$WRAPPER end
SCRIPT3:
#!/bin/bash
export vyatta_sbindir=/opt/vyatta/sbin
export SHELL_API=/opt/vyatta/sbin/my_cli_shell_api
session_env=$($SHELL_API getSessionEnv $PPID)
eval $session_env
cli-shell-api setupSession
cli-shell-api inSession
export SET=${vyatta_sbindir}/my_set
export COMMIT=${vyatta_sbindir}/my_commit
export SAVE=${vyatta_sbindir}/vyatta-save-config.pl
$SET system hostname TEST
$COMMIT
$SAVE
cli-shell-api teardownSession
I’m curious if you could narrow down which command is causing the problem. If you remove the set loopback interface IP command does it still exhibit the problem?
loopback is also my prime suspect.
afaik, if you want to use Cisco-like loopback adapters, use dummy adapter instead
