192.168.82.0/24 is a direct route
set protocols static route 192.168.82.1/32 next-hop ‘192.168.82.1’ track xxx
set protocols static route 192.168.82.1/32 next-hop 10.255.247.22 distance 222
and i see the first route is inactive
I want to make a floating route but failed.
How can I deal with it?
Thanks a lot
Hello Niko.
What version of VyOS you are using?
Your fist command contains “track xxx”. Neither on version 1.2.X, 1.3 and 1.4 that option is available.
You could check your static routes command using “show config comm | match static”, and see if the route that you added is there.
Thanks for your reply.I am using 1.1.8,I can see the route I added using ‘show conf com | grep static’,but when I 'show ip route ',I see that it’s inactive.
Further more,I want to ask if version 1.4 provide VPNV4?
Thanks a lot
Hello Niko
Yes! version 1.4 supports VPNV4/v6 .
best regards
Yep,but I cant find where to define route-target.Is there some MPLSVPN configuration examples?
Thank you so much
at the moment, we don’t have a specific example (with RT like you said), but there are some examples in our blog :
Probably stupid question…but is next-hop directly connected?
yep.next-hop is directly connected
