hi @rituka i was on vacation, any news here?
do you do this:
if something is odd?
mmhh…
the config looks good, just the dns server config is a little bit uncommon.
you have a forwarder configured on vyos and forward to 8.8.8.8 but you also gave 8.8.8.8 as dns-server on dhcp.
are you able to ping e.g. 8.8.8.8 from the wifi client? if yes i would chance the dns config in dhcp:
delete service dhcp-server shared-network-name Wi-Fi subnet 192.168.250.0/24 dns-server ‘192.168.250.1’
if this bring the success, you should overthink your DNS forwarding
Hi @rob
You assumption is correct. This is something with DNS only.
This change has been done and still no success.
Regards
Hello, @rituka!
It is not clear from your messages - are WiFi clients able to ping hosts on the Internet by IP addresses or not? Generally, in most of the situations the problem somewhere in:
Please, make the next tests and write the results.
nslookup google.com 1.1.1.1
