I originally thought this issue was with load balancing, but it is something else. For some reason, as soon as client traffic which is NAT’ed goes through the wwan0 interface, it dies and does not come back until reboot. This is on 1.4-rolling-20220824, however I confirmed the same behavior on 1.4-rolling-20220916 as well. I cannot figure it out!
Here is the scenario: basic setup with client at 10.254.254.11/24 on eth1, with source nat masquerade on wwan0.
When vyos is booted but client is offline, there is no issue. VyOS can use the wwan0 interface with no problems, including downloading files etc. The instant the client comes online the wwan0 connection stops working, not only for the client but also VyOS. The only way to resolve is to disconnect the client and reboot VyOS.
Here is a look at the packet capture from the client network interface (eth1):
Right after the HTTP request, the connection is dead.
Keeping a constant ping on the vyos router to 1.1.1.1, the ping stops immediately after the client comes online. After a minute or so, “no buffer space available”
Here is the full configuration, minimum to reproduce:
firewall {
name drop-invalid {
default-action accept
rule 1 {
action drop
state {
invalid enable
address dhcp
hw-id 00:0c:29:03:37:de
address 10.254.254.1/24
firewall {
in {
name drop-invalid
hw-id 00:0c:29:03:37:e8
loopback lo {
wwan wwan0 {
address 167.XX.XX.143/27
apn b2b.static
nat {
rule 200 {
outbound-interface wwan0
address 10.254.254.0/24
translation {
address masquerade
protocols {
static {
route 0.0.0.0/0 {
next-hop 167.XX.XX.144 {
distance 215
service {
dhcp-server {
shared-network-name lan {
name-server 1.1.1.1
subnet 10.254.254.0/24 {
default-router 10.254.254.1
name-server 1.1.1.1
range 0 {
start 10.254.254.10
stop 10.254.254.250
ssh {
system {
config-management {
commit-revisions 100
conntrack {
modules {
ftp
h323
nfs
pptp
sip
sqlnet
tftp
console {
device ttyS0 {
speed 115200
host-name vyos
login {
user vyos {
authentication {
encrypted-password <>
plaintext-password ""
ntp {
server time1.vyos.net {
server time2.vyos.net {
server time3.vyos.net {
syslog {
global {
facility all {
level info
facility protocols {
level debug
