1:1 range NAT question
So here is what I have.
I have a.b.c.d/24 as the main public IP in the vyos on eth0, and it is also the outgoing route/device.
I have eth4 connected to private network, and an additional eth6 connected to another router in the datacenter.
From eth6, there is a router with vlan 501 and 502 and it has the following IP
vlan 501 x.y.27.65/27
vlan 502 x.y.27.97/27
so What I have done so far is created
eth6.501 and eth6.502 (without any IP address)
eth4 - connected to private network and has the following IPs added.
eth4.101 → 10.0.27.65
eth4.201 → 10.0.27.97
So the requirement is like this.
incoming → x.y.27.66-94 on eth6.501 1:1 NAT to 10.0.27.66-94 on eth4.101
incoming → x.y.27.98-126 on eth6.502 1:1 NAT to 10.0.27.98-126 on eth5.201
and relevant rules for outgoing.
I am hoping that there is some sort of a shortcut so that I do not have to add each IP 1 by 1 to the vyos and then write each rule 1 by 1.
In the private network, there is a servers on the 10.0.27.80 and .100 with gw set to 65/97 respectively on each vlan to test.
Thanks,
On which router do you set ip addresses 100.64.27.65/27 and 100.64.27.97/27?
Is it router “right” or router “vyos”?
Which IP addresses between “vyos” and router “right”? From which directions you want to NAT IP addresses? From eth0, from eth6, some other interface?
It will be cool if you attach a network diagram.
This reduced the execution of the task much faster.
I attached an example.
map
  • eth4.101 has 10.0.113.65 added, which is the gw for servers(.66-94) on vlan 101
  • eth4.201 has 10.0.113.97 added, which is the gw for servers(.98-126) on vlan 201
  • 203.0.113.65 and 203.0.113.97 is reachable on eth6.501 and eth6.502
Todo:
  • 1:1 NAT 203.0.113.64/27 and 203.0.113.96/27 to 10.0.113.64/27 and 10.0.113.97/27
  • The packet should return from the eth6.(501/502) and not eth0
I have not added any 203.0.113.x IP in the vyos (yet)
Try such configuration (in the example only pool 66–70)
set interfaces ethernet eth4 vif 101 address '10.0.27.65/27'
set interfaces ethernet eth4 vif 101 ip proxy-arp-pvlan
set interfaces ethernet eth6 vif 501 address '203.0.113.94/27'
set interfaces ethernet eth6 vif 501 description 'FOO'
set interfaces ethernet eth6 vif 501 ip proxy-arp-pvlan
set interfaces loopback lo
set nat destination rule 66 description 'DNAT-66'
set nat destination rule 66 destination address '203.0.113.66'
set nat destination rule 66 inbound-interface 'eth6.501'
set nat destination rule 66 translation address '10.0.27.66'
set nat destination rule 67 description 'DNAT-67'
set nat destination rule 67 destination address '203.0.113.67'
set nat destination rule 67 inbound-interface 'eth6.501'
set nat destination rule 67 translation address '10.0.27.67'
set nat destination rule 68 description 'DNAT-68'
set nat destination rule 68 destination address '203.0.113.68'
set nat destination rule 68 inbound-interface 'eth6.501'
set nat destination rule 68 translation address '10.0.27.68'
set nat destination rule 69 description 'DNAT-69'
set nat destination rule 69 destination address '203.0.113.69'
set nat destination rule 69 inbound-interface 'eth6.501'
set nat destination rule 69 translation address '10.0.27.69'
set nat destination rule 70 description 'DNAT-70'
set nat destination rule 70 destination address '203.0.113.70'
set nat destination rule 70 inbound-interface 'eth6.501'
set nat destination rule 70 translation address '10.0.27.70'
set nat source rule 66 description 'SNAT-66'
set nat source rule 66 outbound-interface 'eth6.501'
set nat source rule 66 source address '10.0.27.66'
set nat source rule 66 translation address '203.0.113.66'
set nat source rule 67 description 'SNAT-67'
set nat source rule 67 outbound-interface 'eth6.501'
set nat source rule 67 source address '10.0.27.67'
set nat source rule 67 translation address '203.0.113.67'
set nat source rule 68 description 'SNAT-68'
set nat source rule 68 outbound-interface 'eth6.501'
set nat source rule 68 source address '10.0.27.68'
set nat source rule 68 translation address '203.0.113.68'
set nat source rule 69 description 'SNAT-69'
set nat source rule 69 outbound-interface 'eth6.501'
set nat source rule 69 source address '10.0.27.69'
set nat source rule 69 translation address '203.0.113.69'
set nat source rule 70 description 'SNAT-70'
set nat source rule 70 outbound-interface 'eth6.501'
set nat source rule 70 source address '10.0.27.70'
set nat source rule 70 translation address '203.0.113.70'
Ping from ISP2
vyos@isp2:~$ ping 203.0.113.67 count 2
PING 203.0.113.67 (203.0.113.67) 56(84) bytes of data.
64 bytes from 203.0.113.67: icmp_seq=1 ttl=63 time=2.06 ms
64 bytes from 203.0.113.67: icmp_seq=2 ttl=63 time=1.81 ms
--- 203.0.113.67 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 3ms
rtt min/avg/max/mdev = 1.812/1.934/2.056/0.122 ms
vyos@isp2:~$
vyos@isp2:~$ ping 203.0.113.68 count 2
PING 203.0.113.68 (203.0.113.68) 56(84) bytes of data.
64 bytes from 203.0.113.68: icmp_seq=1 ttl=63 time=597 ms
64 bytes from 203.0.113.68: icmp_seq=2 ttl=63 time=1.37 ms
--- 203.0.113.68 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 2ms
rtt min/avg/max/mdev = 1.365/299.381/597.397/298.016 ms
vyos@isp2:~$
vyos@isp2:~$ ping 203.0.113.69 count 2
PING 203.0.113.69 (203.0.113.69) 56(84) bytes of data.
64 bytes from 203.0.113.69: icmp_seq=1 ttl=63 time=506 ms
64 bytes from 203.0.113.69: icmp_seq=2 ttl=63 time=1.33 ms
--- 203.0.113.69 ping statistics ---
rtt min/avg/max/mdev = 1.330/253.849/506.368/252.519 ms
vyos@isp2:~$
The dump from “private”
vyos@vyos:~$ sudo tcpdump -nti eth0.101
listening on eth0.101, link-type EN10MB (Ethernet), capture size 262144 bytes
IP 203.0.113.65 > 10.0.27.67: ICMP echo request, id 2584, seq 1, length 64
IP 10.0.27.67 > 203.0.113.65: ICMP echo reply, id 2584, seq 1, length 64
ARP, Request who-has 10.0.27.67 tell 10.0.27.65, length 28
ARP, Reply 10.0.27.67 is-at 50:00:00:01:00:00, length 28
IP 203.0.113.65 > 10.0.27.67: ICMP echo request, id 2607, seq 1, length 64
IP 10.0.27.67 > 203.0.113.65: ICMP echo reply, id 2607, seq 1, length 64
IP 203.0.113.65 > 10.0.27.67: ICMP echo request, id 2607, seq 2, length 64
IP 10.0.27.67 > 203.0.113.65: ICMP echo reply, id 2607, seq 2, length 64
ARP, Request who-has 10.0.27.68 tell 10.0.27.65, length 28
ARP, Reply 10.0.27.68 is-at 50:00:00:01:00:00, length 28
IP 203.0.113.65 > 10.0.27.68: ICMP echo request, id 2630, seq 1, length 64
IP 10.0.27.68 > 203.0.113.65: ICMP echo reply, id 2630, seq 1, length 64
IP 203.0.113.65 > 10.0.27.68: ICMP echo request, id 2630, seq 2, length 64
IP 10.0.27.68 > 203.0.113.65: ICMP echo reply, id 2630, seq 2, length 64
Sorry for the late reply.
This works … I am from outside able to ping and reach the servers internally.
Many thanks.
