[1.2.0 RC5] Some ipsec related commands do not work
Hi all,
Not sure if this is a bug but it seems to be.
VPN are running just fine, but these commands does not seem to work fine:
vyos@vyos:~$ show vpn ipsec state
RTNETLINK answers: Operation not permitted
Dump terminated
And:
vyos@vyos:~$ show vpn ipsec sa
Peer ID / IP Local ID / IP
aa.bb.cc.dd 172.16.16.77
Tunnel State Bytes Out/In Encrypt Hash NAT-T A-Time L-Time Proto
vti down 2.3K/2.6K 3des md5_96 no -1080 all
172.16.16.101 172.16.16.92
vti down 0.0/0.0 3des md5_96 no -1200 all
state is reported as down but traffic is flowing and A-TIme is reporting negative numbers
This command seems to work fine:
vyos@vyos:~$ show vpn ipsec status
IPSec Process Running PID: 2930
2 Active IPsec Tunnels
IPsec Interfaces :
eth0 (172.16.16.77)
eth1 (172.16.16.92)
This command also does not work:
vyos@vyos:~$ monitor vpn ipsec
tail: unrecognized file system type 0x794c7630 for ‘/var/log/messages’. please report this to [email protected]. reverting to polling
To add some useful info we upgraded from 1.1.7 to 1.1.8 and then straight to 1.2.0-rc5
The first one is related to this Phabricator entry: ⚓ T930 "show vpn ipsec policy" does not work in VyOS 1.2 rc3
The second command (monitor vpn ipsec) seems to be another bug
Second one ist related to this one ⚓ T188 tail: unrecognized file system type 0x794c7630.
You are right.
I was not able to find the relevant phabricator ticket because the search function did timeout.
