Using vyos-1.2.0-rolling+201903120337-amd64, problem when adding /24 static routes into VyOS so they propagate into BGP.
If I add a static route via conf it doesn’t propagate into the routing table: # set pro static route 193.x.x.0/24 next-hop 10.254.254.2 distance 1 # commit # save # exit $ sh ip route 193.x.x.0/24 % Network not in table $ sh ip bgp 193.x.x.0/24 % Network not in table
But if I add the route via sudo, it appears as a kernel route, but not into BGP because we don’t allow kernel routes to redistribute: $ sudo ip route add 193.x.x.0/24 via 10.254.254.2 $ sh ip route 193.x.x.0/24 Routing entry for 193.x.x.0/24 Known via "kernel", distance 0, metric 0, best Last update 00:00:05 ago * 10.254.254.2, via eth1 $ sh ip bgp 193.x.x.0/24 % Network not in table
The local IP on the router is 10.254.254.253, the next hop, 10.254.254.2 is directly connected on a flat ethernet segment, connectivity between the hosts is fine.
To me it seems that there’s something wrong with how static routes are being injected from config mode. I’ve found similar posts on here, and on google relating to Ubnt’s version of Vyatta, but nothing specific to VyOS 1.2, and nothing helpful as yet. Has anyone else seen this? any ideas?
The prefix is allowed in a prefix-list, the prefix list is allowed in the route-map, and the route-map is the export within BGP. The route however never gets injected into BGP because it needs to be in the routing table locally first
# sh pol route-map
route-map BGP-Export-To-Carrier {
rule 1 {
action permit
match {
ip {
address {
prefix-list BGP-Export-To-Carrier
rule 2 {
action permit
match {
ip {
address {
prefix-list BGP-Blackhole
# sh pol prefix-list BGP-Export-To-Carrier
<snip>
rule 9 {
action permit
prefix 193.x.x.0/24
<snip>
…seems to have been an issue for some time, now fixed in the H4 update for 1.2.0. As we’re still evaluating 1.2 before committing to a subscription we don’t have access behind the paywall yet. We’ve reverted back to 1.1.8 on the routers we’ve upgraded.
If H4 appears in the rolling release sometime (not sure how to check that!), we can retest.
