1.3-rolling-202007152012 - can't disable Ethernet interface
Hi All
Before I log a bug I wanted to make sure it’s not just me.
For the last 2-3 1.3 rolling releases I’ve tried, I’m unable to disable Ethernet interfaces. eth0 in this case.
I have a “standby” VyOS instance and using VRRP scripts, my interface to the Internet gets enabled or disabled depending on the VRRP status (I disable as I use the same MAC on both routers as my ISP filters MACs).
…but I’m finding that when I try a 1.3 rolling on the standby instance, the interface doesn’t get disabled and so I have routing issues (not to mention duplicate MACs towards the Internet).
If I try to manually disable the interface it says it’s already disabled, and if I bounce the interface it seems to work but it remains up.
If I go back to 1.2, there’s no issues.
Anyone else experiencing similar issues?
(sorry I don’t have screen grabs at the moment as I needed to stabilise my connection)
Cheers
Chris…
I’m not using 1.3-rolling so I can’t test easily, but if you are able to reliably reproduce this you would be doing the Vyos team (and us all) a huge favour if you could log a Phabricator ticket about it.
Or if you’re not keen to do that, write all the details here (logs too if possible please) and I can log one on your behalf.
(Also, hello fellow Patron, thanks for supporting the project!)
Hi @cmonck, I think this is know issue ⚓ T2106 Wrong interface states after reboot
