Rolling 1.4 (2021-10-13)
I try to drop ping traffic by the firewall-out rule, but it’s not working. The rule works OK as firewall-local though:
rule 20 {
action drop
description “TEST”
protocol icmp}
Output is used for FORWARD chain. It is described in our Documentation
If you want to disable ping from the local router you may use Zone-policy firewall
Thank you! Can you give me example how use zone-policy ruleset to disable ping from router? My ruleset was like this:
default-action accept
rule 20 {
action drop
description “TEST: hide beacons”
destination {
address 4.2.2.0/30
protocol icmp
