1.4 rolling release build problem
Got the following message while building VyOS rolling release ISO :
libstrongswan-standard-plugins : Depends: libssl1.1 (>= 1.1.1) but it is not installable
(live)root@b904a1aa4e9c:/#
root@b904a1aa4e9c:/vyos# sudo chroot build/chroot /bin/bash
(live)root@b904a1aa4e9c:/# mount -t proc none /proc
(live)root@b904a1aa4e9c:/# mount -t sysfs none /sys
(live)root@b904a1aa4e9c:/# mount -t devtmpfs none /dev
(live)root@b904a1aa4e9c:/# apt-get update
Get:1 Index of /debian-security buster/updates InRelease [34.8 kB]
Hit:2 Index of /debian bookworm InRelease
Get:3 Index of /debian-security bookworm-security InRelease [48.0 kB]
Hit:4 Index of /debian bookworm-updates InRelease
Hit:5 https://repo.saltproject.io/py3/debian/11/amd64/3004 bullseye InRelease
Hit:6 Index of /debian bookworm-backports InRelease
Hit:7 Index of /debian buster InRelease
Hit:8 Index of /debian buster-updates InRelease
Hit:9 http://dev.packages.vyos.net/repositories/current current InRelease
Fetched 82.8 kB in 2s (37.2 kB/s)
Reading package lists… Done
(live)root@b904a1aa4e9c:/# apt-get install vyos-1x
Building dependency tree… Done
Reading state information… Done
Some packages could not be installed. This may mean that you have
(live)root@b904a1aa4e9c:/# apt-get install libssl1.1
Package libssl1.1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘libssl1.1’ has no installation candidate
(live)root@b904a1aa4e9c:/#general
How can i fix this?
After changes from bullseye to bookworm we are still working on it.
Thank you, Viacheslav
I just checked the rolling release from Feb 15 and it’s still bullseye.
When has it changed?
https://vyos.dev/T5003
