1.5: Show interface wireguard wg05 summary not working rolling release 2025-02-16
Hello, i think there maybe a bug in the last release:
vyos@stronghold:~$ show interfaces wireguard wg05
Possible completions:
Execute the current command
allowed-ips Show all IP addresses allowed for the specified interface
endpoints Show all endpoints for the specified interface
event-log Show network interface change event log
peers Show all peer IDs for the specified interface
public-key Show interface public-key
summary Shows current configuration and device information
vyos@stronghold:~$ show interfaces wireguard wg05 summary
File “/usr/libexec/vyos/op_mode/interfaces_wireguard.py”, line 48, in
res = vyos.opmode.run(sys.modules[name])
File “/usr/lib/python3/dist-packages/vyos/opmode.py”, line 312, in run
res = func(**args)
File “/usr/libexec/vyos/op_mode/interfaces_wireguard.py”, line 35, in _wrapper
return func(*args, **kwargs)
File “/usr/libexec/vyos/op_mode/interfaces_wireguard.py”, line 43, in show_summary
return intf.operational.show_interface()
Thanks
Does show interfaces show you wg05 with no issues?
I’ll test this myself and see what I find.
Can you be clear when you say the “latest release” exactly what version of VyOS you’re running?
Thanks!
no problem running :
wg05: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet ….scope global wg05
inet6 …. scope link
Description: Stronghold ↔ Lothal
RX:       bytes  packets  errors  dropped  overrun       mcast
     1981340536  1534114       0        0        0           0
TX:       bytes  packets  errors  dropped  carrier  collisions
      243175032   726627       0        0        0           0
vyos@stronghold:~$
I’m using 1.5 rolling release of 16 february 2025.
Thanks
The task is already in forge T7123
Raised here also
Hello, just update to the last rolling release: 20250222, i got another error:
vyos@shieldgate:~$ show interfaces wireguard wg05
link/none
inet *** scope global wg05
inet6 **** scope link
Description: Lothal ↔ Stronghold
     21734160    34413       0        0        0           0
      3209772    25621       0        0        0           0
vyos@shieldgate:~$ show interfaces wireguard wg05 summary
res = func(**args)
File “/usr/lib/python3/dist-packages/vyos/ifconfig/wireguard.py”, line 121, in show_interface
delta = timedelta(
NameError: name ‘timedelta’ is not defined
I got the same issue. I rolled back to 202501200007, that works perfect.
Please test in the latest rolling release.
Works great in the last rolling release.
Thanks!!!
Works here as well! Great, thank you very much!
