1.5: system options ssh-client source-interface traceback
1.5 compiled on 20240703 (05e3f87975a3fd)
Attempting to set system option ssh-client source-interface lo results in the below upon commit. Unsure if related to T4922 or not.
[edit system option]
adam@r20. show
 kernel {
     disable-power-saving
 performance latency
+ssh-client {
+    source-interface lo
 time-format 24-hour
adam@r20# commit
[ system option ]
  https://support.vyos.io/
- Make sure you are running the latest version of VyOS available at:
  https://vyos.net/get/
- Consult the community forum to see how to handle this issue:
  https://forum.vyos.io
- Join us on Slack where our users exchange help and advice:
  https://vyos.slack.com
  business policy requires it)
Report time:      2024-08-20 15:06:30
Image version:    VyOS 1.5-circinus-2024Q2
Release train:    current
Built by:         adam.korab@sixpackets.com
Built on:         Wed 03 Jul 2024 21:48 UTC
Build UUID:       405c1ef3-4223-4c11-a2d3-baa4cc16b16d
Build commit ID:  05e3f87975a3fd
Architecture:     x86_64
System type:      bare metal
Hardware vendor:  Supermicro
Hardware model:   Super Server
Hardware S/N:     0123456789
Hardware UUID:    00000000-0000-0000-0000-0cc47acce462
  File "/usr/libexec/vyos/conf_mode/system_option.py", line 180, in <module>
    verify(c)
  File "/usr/libexec/vyos/conf_mode/system_option.py", line 81, in verify
    verify_source_interface(config)
  File "/usr/lib/python3/dist-packages/vyos/configverify.py", line 277, in verify_source_interface
    ifname = config['ifname']
KeyError: 'ifname'
[[system option]] failed
Commit failed
Thank you for reporting. This is the bug report ⚓ T6672 ssh-client source-interface CLI option failing with traceback, you can subscribe yourself for updates.
