I would like to create a 4 router lab in the classroom to demonstrate dynamic routing. I have previously done this with Windows Server but that is not realistic. I setup 4 routers with 6 links interconnecting all routers using RIP. Links as follows 1-2, 1-3, 1-4, 2-3, 2-4, 3-4. Router 1 also has a connection to the internet. Links use 10.1.1.0/30, 10.1.1.4/30, 10.1.1.8/30, 10.1.1.12/30, 10.1.1.16/30, 10.1.1.20/30
I used the following commands for example on router1.
set interfaces ethernet eth0 address dhcp
set interfaces ethernet eth0 description ‘External’
set interfaces ethernet eth1 address 192.168.1.1/24
set interfaces ethernet eth1 description ‘Subnet1’
set interfaces ethernet eth2 address 10.1.1.1/30
set interfaces ethernet eth2 description ‘Link1-2’
set interfaces ethernet eth3 address 10.1.1.5/30
set interfaces ethernet eth3 description ‘Link1-3’
set interfaces ethernet eth4 address 10.1.1.9/30
set interfaces ethernet eth4 description ‘Link1-4’
set protocols rip network 192.168.1.0/24
set protocols rip interface eth1
set protocols rip neighbor 10.1.1.2
set protocols rip neighbor 10.1.1.6
set protocols rip neighbor 10.1.1.10
set protocols rip passive-interface default
RIP fails to work if I drop any single link. Can anyone suggest what I am doing wrong or if there is a better way to do this?
Also when posting config please use “show config commands” or if it might contain sensitive information use “show config commands | strip-private” to have a scrubbed edition for pasting.
