I want to integrate a VM running VyOS into Acronis Backup (cloud).
For this to work i need to install a “agent” provided by Acronis.
For this to work the installer needs the kernel headers.
How can i provide the kernel headers for the installer?
Without i get following error message:
“failed to build the SnapAPI kernel module. Operations with disk-level backups will not be available.”
Please keep in mind that using repos is not officially supported anymore, OS updates and the such are being distributed via the iso. But apt-get install will still work though, but use it at your own risk.
