On vanilla HAproxy that I run manually, I have a ssh load balanced setup with source persistence AND least-connection balancing, like this:
listen ssh
bind <my ip>:22
stick-table type ip size 1k expire 48h
stick on src
balance leastconn
mode tcp
So I keep a stick table for 48hrs and use it for source IP persistence. If not in the table, use least-connection logic to distribute load across my two backends. Works perfectly. I’m migrating this setup to VyOS and I notice I can choose one of either, or round-robin:
admin@<hostname># set backend logins balance
Possible completions:
source-address Based on hash of source IP address
round-robin Round robin (default)
least-connection Least connection
But I can’t have both, even though HAproxy supports this with the config shown above.
Feature request:
Add the stick table option to the VyOS CLI, so I can have source persistence via stick table and not hashed assignments, and combine it with least-connection balancing.
Thanks! I have applied for an account at vyos.dev. Will post it there when I can.
To get to my config I could see a CLI like this:
set load-balancing haproxy backend <backend> balance least-connection
set load-balancing haproxy backend <backend> mode tcp
set load-balancing haproxy backend <backend> stick-table type ip
set load-balancing haproxy backend <backend> stick-table size 1k
set load-balancing haproxy backend <backend> stick-table expire 48h
set load-balancing haproxy backend <backend> stick-on src
Resulting in config:
[edit load-balancing]
admin@l<hostname># show
haproxy {
backend <backend> {
mode tcp
stick-table {
type ip
size 1k
expire 48h
stick-on src
<rest of config...>
But stick tables do more than just this. My example comes from this page:
But stick tables can be used to track lots of other stuff and apply ACL’s on them. Config manual with all the options:
So implementing all of the stick-table options is a larger task. Would it be preferred to add all the options, or (at first) a selection of the most common/useful options?
