I would like to add a kvm module to VyOS kernel.
Is that possible ?
I failed recompiling the kernel beacause of the build directory missing.
Does a faqs or how to exist for recompiling while adding new module ?
Thank you verys much.
EDIT: here is what i got when trying to build the module:
root@vyos:~/kvm-kmod# make LINUX=../kvm clean sync all
make -C /usr/src/linux-image/debian/build/build-i386-none-586-vyos M=`pwd` clean
make[1]: Entering directory `/usr/src/linux-image/debian/build/build-i386-none-586-vyos'
CLEAN /root/kvm-kmod/.tmp_versions
make[1]: Leaving directory `/usr/src/linux-image/debian/build/build-i386-none-586-vyos'
./sync -v for-linus-524-ge35b8d9b -l ../kvm
make -C /usr/src/linux-image/debian/build/build-i386-none-586-vyos M=`pwd` \
LINUXINCLUDE="-I`pwd`/include -I`pwd`/include/uapi -Iinclude \
-Iinclude/uapi -Iarch/x86/include -Iarch/x86/include/uapi \
-Iinclude/generated/uapi -Iarch/x86/include/generated \
-Iarch/x86/include/generated/uapi \
-I`pwd`/include-compat -I`pwd`/x86 \
-include include/generated/autoconf.h \
-include `pwd`/x86/external-module-compat.h" \
LD /root/kvm-kmod/x86/built-in.o
CC [M] /root/kvm-kmod/x86/svm.o
In file included from <command-line>:0:
/root/kvm-kmod/x86/external-module-compat.h:527:2: error: #error Preemption notifier emulation does not work for this kernel.
make[3]: *** [/root/kvm-kmod/x86/svm.o] Error 1
make[2]: *** [/root/kvm-kmod/x86] Error 2
make[1]: *** [_module_/root/kvm-kmod] Error 2
make: *** [all] Error 2
Seems that’s not possible with this kernel.
