Hi there!
I’m trying to update rolling release, but it it’s failed:
wins@vyos:~$ show ver
Version: VyOS 1.2-rolling-201908171224
Built by: autobuild@vyos.net
Built on: Sat 17 Aug 2019 12:24 UTC
Build UUID: 0ef539be-8d54-4dc6-bbfd-78e09f8e6ab3
Build Commit ID: 204e0cb825de1d
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: Dell Inc.
Hardware model: PowerEdge R210 II
Installing "1.2-rolling-201908310337" image.
Copying new release files...
Error trying to mount a partition/directory.
Please see /tmp/install-9270.log for details
Log file:
mount -t overlay -o noatime,upperdir=/boot/1.2-rolling-201908310337/rw,lowerdir=/mnt/squashfs,workdir=/boot/1.2-rolling-201908310337/work overlay /mnt/inst_root
mount: wrong fs type, bad option, bad superblock on overlay,
missing codepage or helper program, or other error
Hello @wins, I can’t reproduce issue with update and on old rolling versions, can you provide more information. show disk sda format sudo dmesg | grep sda
and sudo df -lah
[1188561.669553] ISO 9660 Extensions: Microsoft Joliet Level 3
[1188561.674433] ISO 9660 Extensions: RRIP_1991A
[1188567.100778] overlayfs: filesystem on '/boot/1.2-rolling-201908310337/rw' not supported as upperdir
[1188982.527455] ISO 9660 Extensions: Microsoft Joliet Level 3
[1188982.527504] ISO 9660 Extensions: RRIP_1991A
[1188987.321587] overlayfs: filesystem on '/boot/1.2-rolling-201908310337/rw' not supported as upperdir
[1190232.620481] ISO 9660 Extensions: Microsoft Joliet Level 3
[1190232.620530] ISO 9660 Extensions: RRIP_1991A
[1190235.636200] overlayfs: filesystem on '/boot/1.2-rolling-201908310337/rw' not supported as upperdir
So, I can’t reproduce this issue, can you show me full update process? Begin command: add system image https://downloads.vyos.io/rolling/current/amd64/vyos-1.2-rolling-201908310337-amd64.iso
wins@vyos:~$ add system image https://downloads.vyos.io/rolling/current/amd64/vyos-1.2-rolling-201909041703-amd64.iso
Trying to fetch ISO file from https://downloads.vyos.io/rolling/current/amd64/vyos-1.2-rolling-201909041703-amd64.iso
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 408M 100 408M 0 0 1468k 0 0:04:44 0:04:44 --:--:-- 1504k
ISO download succeeded.
Checking for digital signature file...
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (22) The requested URL returned error: 404 Not Found
Unable to fetch digital signature file.
Do you want to continue without signature check? (yes/no) [yes]
Checking MD5 checksums of files on the ISO image...OK.
Done!
What would you like to name this image? [1.2-rolling-201909041703]:
OK. This image will be named: 1.2-rolling-201909041703
Installing "1.2-rolling-201909041703" image.
Please see /tmp/install-6535.log for details.
Failed to set up root directory for postinst
