I’m using VyOS on a quite slow machine (CPU is Intel J1900), and I’m getting frequent commit timeouts when running an Ansible playbook to setup the machine. Adjusting the Ansible task timeout makes no difference.
If I run the same set of commands manually, it’s all fine.
Typical error message:
failed: [liberal] (item={'name': 'wan-in', 'default-action': 'drop', 'description': 'Chain WAN', 'rules': {100: ["action 'drop'", "recent count '4'", "recent time 'minute'", "state new 'enable'", "destination port '22'", "protocol 'tcp'"], 101: ["action 'accept'", "destination port '22'", "protocol 'tcp'", "state new 'enable'"]}}) => {"ansible_loop_var": "item", "changed": false, "item": {"default-action": "drop", "description": "Chain WAN", "name": "wan-in", "rules": {"100": ["action 'drop'", "recent count '4'", "recent time 'minute'", "state new 'enable'", "destination port '22'", "protocol 'tcp'"], "101": ["action 'accept'", "destination port '22'", "protocol 'tcp'", "state new 'enable'"]}}, "msg": "commit failed: timeout value 30 seconds reached while trying to send command: b'commit comment \"configured by vyos_config\"'"}
[ERROR]: Traceback (most recent call last): File "/nix/store/hxhb2al3zgvzlgz0s1vpxzfqhvh9yzhj-
python3.10-paramiko-2.11.0/lib/python3.10/site-packages/paramiko/channel.py", line 699, in recv out = self.in_buffer.read(nbytes,
self.timeout) File "/nix/store/hxhb2al3zgvzlgz0s1vpxzfqhvh9yzhj-python3.10-paramiko-2.11.0/lib/python3.10/site-
packages/paramiko/buffered_pipe.py", line 164, in read raise PipeTimeout() paramiko.buffered_pipe.PipeTimeout During handling of the
above exception, another exception occurred: Traceback (most recent call last): File
"/home/oscar/.ansible/collections/ansible_collections/ansible/netcommon/plugins/connection/network_cli.py", line 1056, in send
response = self.receive( File
"/home/oscar/.ansible/collections/ansible_collections/ansible/netcommon/plugins/connection/network_cli.py", line 1005, in receive
response = self.receive_paramiko( File
"/home/oscar/.ansible/collections/ansible_collections/ansible/netcommon/plugins/connection/network_cli.py", line 813, in receive_paramiko
data = self._ssh_shell.recv(256) File "/nix/store/hxhb2al3zgvzlgz0s1vpxzfqhvh9yzhj-python3.10-paramiko-2.11.0/lib/python3.10/site-
packages/paramiko/channel.py", line 701, in recv raise socket.timeout() TimeoutError
My datastructure is quirky but easy to write, used together with a custom filter which should output the following lines based on the payload in the error message above:
set firewall ipv4 name wan-in default-action 'drop'
set firewall ipv4 name wan-in description 'Chain WAN'
set firewall ipv4 name wan-in rule 100 action 'drop'
set firewall ipv4 name wan-in rule 100 recent count '4'
set firewall ipv4 name wan-in rule 100 recent time 'minute'
set firewall ipv4 name wan-in rule 100 state new 'enable'
set firewall ipv4 name wan-in rule 100 destination port '22'
set firewall ipv4 name wan-in rule 100 protocol 'tcp'
set firewall ipv4 name wan-in rule 101 action 'accept'
set firewall ipv4 name wan-in rule 101 destination port '22'
set firewall ipv4 name wan-in rule 101 protocol 'tcp'
set firewall ipv4 name wan-in rule 101 state new 'enable'
This is the task in my playbook:
- name: Setup custom chains
vyos.vyos.vyos_config:
lines: "{{ item | vyos_split_chain }}"
when: vyos_firewall_chains is defined
loop: "{{ vyos_firewall_chains }}"
tags: firewall_chains
My VyOS version:
Version: VyOS 1.5-rolling-202310010025
Release train: current
Built by: autobuild@vyos.net
Built on: Sun 01 Oct 2023 01:49 UTC
Build UUID: faa9f6a7-91d3-4674-9230-57c4b4ab5d79
Build commit ID: 352cfe5761c92b
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: To be filled by O.E.M.
Hardware model: To be filled by O.E.M.
Hardware S/N: To be filled by O.E.M.
Hardware UUID:
I thought sending a list of commands (like the vyos_split_chain outputs) should make them go in one commit, but it’s either done in multiple commits, or my computer is just too slow? Timeout is 30 s.
Can I increase the timeout? It doesn’t seem to be an Ansible timeout in this case, as adjusting it in the task makes no difference.
Also - having netfilter style filters in VyOS is awesome, finally! ![]()
