Another Port Forward/Firewall Issue
I installed Vyos today to learn the system and play around with it, but I can’t seem to get port forwarding working. I’m trying to forward 32400 to an internal IP of 192.168.1.200, but it’s not working after adding bother firewall forwarding rules and NAT destination rules. This is a new installation of 1.4. What am I doing wrong?
Thanks!
ILLY
nat {
     destination {
         rule 10 {
             description "PLEX Port Forward"
             destination {
                 port 32400
             inbound-interface {
                 name eth0
             protocol tcp
             translation {
                 address 192.168.1.200
         rule 100 {
             outbound-interface {
                 name eth0
                 address 192.168.1.0/24
             translation {
                 address masquerade
firewall {
     global-options {
         state-policy {
             established {
                 action accept
             invalid {
                 action drop
             related {
                 action accept
     group {
         interface-group LAN {
             interface eth8
         interface-group WAN {
             interface eth0
         network-group NET-INSIDE-v4 {
             network 192.168.1.0/24
     ipv4 {
         forward {
             filter {
                 rule 10 {
                     action accept
                     connection-status {
                         nat destination
                     state new
                 rule 100 {
                     action jump
                     destination {
                         group {
                     inbound-interface {
                         group WAN
                     jump-target OUTSIDE-IN
         input {
             filter {
                 default-action drop
                 rule 20 {
                     action jump
                     destination {
                         port 22
                     jump-target VyOS_MANAGEMENT
                     protocol tcp
                 rule 30 {
                     action accept
                     icmp {
                         type-name echo-request
                     protocol icmp
                     state new
                 rule 40 {
                     action accept
                     destination {
                         port 53
                     protocol tcp_udp
                         group {
                 rule 50 {
                     action accept
                         address 127.0.0.0/8
         name OUTSIDE-IN {
             default-action drop
         name VyOS_MANAGEMENT {
             default-action return
             rule 15 {
                 action accept
                 inbound-interface {
                     group LAN
             rule 20 {
                 action drop
                 inbound-interface {
                     group WAN
                 recent {
                     count 4
                     time minute
                 state new
             rule 21 {
                 action accept
                 inbound-interface {
                     group WAN
                 state new
You can use tcpdump to see if traffic is being received and forward to desired interface:
sudo tcpdump -ni any port 32400
you can also enable log for rules and check logs and counters.
I was able to solve this by changing the rule 10 under forward filter to call out the DNAT setting explicitly.
Here is my config under ipv4 forward filter that worked. Instead of the rule 10 above, I used the following:
rule 10 {
                     action accept
                     destination {
                         port 32400
                     protocol tcp
                     state new
Possible for you to bring how the finaly solution looks like configwise (so future readers can compare with your initial post)?
I think @azhagan refers to the explicit rules by @cnrd in related topic https://forum.vyos.io/t/any-differences-in-firewall-configuration-syntax-between-1-4-rolling-202312140147-and-1-4-0-epa1/
It does smell of a DNAT matching bug…
I updated my post with the rule that I ended up using for clarity.
