Ansible error - "msg": "q must be exactly 160, 224, or 256 bits long"}
Hi I am trying to configure a VyOS VM deployed on ovirt.
I am getting “msg”: “q must be exactly 160, 224, or 256 bits long”} error when trying to configure VyOS VM.
I am using vyos_vlan module.
My inventory file looks like below
[VyOS]
j3rrvyos1 ansible_ssh_host=10.41.170.96 ansible_user=vyos ansible_ssh_pass=vyos ansible_network_os=vyos ansible_connection=network_cli ansible_python_interpreter=/usr/bin/python3
I am not sure why I am getting this q error when trying to configure the vm.
~Below is the module I am trying to execute.
  • name: Configure virtual LAN’s and interface address
    vyos_vlan:
    vlan_id: “{{ networks.value.id }}”
    interfaces: “eth1”
    address: “{{ networks.value.ipv4 }}/24”
    name: “{{ networks.value.name }}”
Hi @qwerty,
The problem seems to be on the control host side, not the VyOS side.
Could you provide the contents of the .ssh/config file of the user from which the Ansible scripts run?
Hi @Nikolay , there is no ssh/config file.
I temporary fixed by switching switch ssh type from paramiko to libssh and now it is working.
It looks there might be bug for paramiko.
<10.41.170.53> attempting to start connection
<10.41.170.53> using connection plugin ansible.netcommon.network_cli
Found ansible-connection at path /usr/local/bin/ansible-connection
<10.41.170.53> found existing local domain socket, using it!
**<10.41.170.53> invoked shell using ssh_type: libssh**
<10.41.170.53> ssh connection done, setting terminal
<10.41.170.53> loaded terminal plugin for network_os vyos.vyos.vyos
<10.41.170.53> firing event: on_open_shell()
<10.41.170.53> ssh connection has completed successfully
<10.41.170.53> updating play_context for connection
<10.41.170.53>
<10.41.170.53> local domain socket path is /root/.ansible/pc/6b5c2da01c
redirecting (type: action) vyos.vyos.vyos_vlan to vyos.vyos.vyos
[WARNING]: provider is unnecessary when using network_cli and will be ignored
<10.41.170.53> ANSIBLE_NETWORK_IMPORT_MODULES: disabled
<10.41.170.53> ANSIBLE_NETWORK_IMPORT_MODULES: module execution time may be extended
<10.41.170.53> ESTABLISH LOCAL CONNECTION FOR USER: root
